09-30-2018, 04:02 | #4 (permalink) |
Junior Member Join Date: Jan 2013 Location: India
Member: 1862559 Status: Offline Thanks Meter: 4 | Not Done Not Working Device : Xiaomi Redmi Note 5 Pro (Test) Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Preparing Loader...Done Sending Loader [Note5Pro]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5= Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 2.9 |
09-30-2018, 05:26 | #5 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: GSM Forum Age: 27
Member: 2559216 Status: Offline Thanks Meter: 220 | Quote:
Try install latest drivers Make sure battery is connected in mob. Use another port/cable. Note-the above problem is confirmed bcoz i tested Lower and latest higher version of firmware is working in qcfir. Br | |
09-30-2018, 07:46 | #6 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: hyderabad, india
Member: 1623940 Status: Offline Thanks Meter: 22 | Use 2.8 Quote:
i have same issue, just use 2.8ver problem solved | |
09-30-2018, 07:56 | #7 (permalink) |
Registered User Join Date: Nov 2001 Location: close to your mind Age: 53
Member: 7457 Status: Offline Thanks Meter: 21 | REDMI note 5 pro 10000000% working with version 9.5.13 after mi account unlock its lost wifi, not worry use update with versionn 10.0 make it factory reset with sideload. now all clear, everything is ok. use qualcomm 2.8 |
