04-17-2021, 17:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Unable to flash Nokia 2.1 TA-1080 Device : Nokia 2.1 (TA-1080) Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM42) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : A57FDEEB0D02233786D8DDCA8A9889D62F92D43EE56EAC9966 024663C39A5B06 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_021]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, EMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : FIH E2M [E2M] Brand : FIH Prod.Name : E2M_00WW_FIH Software : 00WW_1_13C, 00WW_1_13C [Tue May 7 17:40:45 CST 2019] Android Ver. : 9 Patch Level : 2019-05-01 USERDATA : Encrypted You can use DISABLE LOCKS to Disable Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 6.7 |
04-17-2021, 20:14 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | What happens if you click Flash? It should Warn you about missing files, but should proceed to flash. If not, please untick missing file and try again. Br, UMT |
