Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 08-01-2020, 16:34   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
why not flash redmi note 7s
this model is supported offline flash when i flash need auth why
peration : Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM10)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1C00800 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8996_022]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Reading Auth Blob...Not Found!
DebugData : BAAAABAAAAANAAAAAQAAAA==
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Finished.
Old 08-01-2020, 19:00   #2 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
This is issue with device connection.
If software says that phone is asking for auth, then it must read Auth Blob.
If it says Auth Blob not found, that means there is some communication issue.
In such case, just disconnect cable and battery, let board disharge, or hold power button for 10 seconds. After that connect battery and use TP to connect phone to PC.
Br,
UMT
The Following 2 Users Say Thank You to U.M.T For This Useful Post:
Page generated in 0.10922 seconds with 8 queries
