Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 02-08-2020, 11:16   #16 (permalink)
Ankit Verma's Avatar
Member: 506648
Sonork: 100.1614254
Thanks Meter: 688
Easy way to attach resistor on Umt Emmc Isp Hardware Tool
The Following 4 Users Say Thank You to Ankit Verma For This Useful Post:
Old 02-09-2020, 14:28   #17 (permalink)
Member: 2866528
Thanks Meter: 93
also find you video on this topic .....
http://www.youtube.com/watch?v=LVWlmBxJ82A
The Following 4 Users Say Thank You to vmcindore For This Useful Post:
Old 02-09-2020, 14:29   #18 (permalink)
Member: 2866528
Thanks Meter: 93
The Following User Says Thank You to vmcindore For This Useful Post:
Old 02-13-2020, 09:39   #19 (permalink)
Member: 2866528
Thanks Meter: 93
How to use VCC 2.8 Voltage on Umt Emmc Isp Tool
http://www.youtube.com/watch?v=Nh_8spBTpHg
The Following 3 Users Say Thank You to vmcindore For This Useful Post:
Old 02-20-2020, 09:49   #20 (permalink)
Member: 506648
Sonork: 100.1614254
Thanks Meter: 688
Umt Emmc Isp Tool Tutorial Lesson 1 | How to Connect Isp Pinout by Umt Emmc Isp Tool
http://www.youtube.com/watch?v=iumxKh9qEds
The Following User Says Thank You to Ankit Verma For This Useful Post:
Old 05-08-2020, 10:16   #21 (permalink)
Member: 2945168
Thanks Meter: 6
Originally Posted by Ankit Verma View Post
Why Umt Emmc Isp Hardware Tool Not Connect to Emmc
100% Tested Solution
http://www.youtube.com/watch?v=6w6CKWu_zKg
100% working thanks.,.....
Old 05-26-2020, 10:25   #22 (permalink)
Member: 2090361
oppo a1k reading error
Opening Device...Done
Physical Details:
Chip Size : 0x747C00000 [29.12 GB]
Sector Size : 0x0200
Sector Count : 0x03A3E000
Reading Partition Data...Failed
Old 05-27-2020, 07:29   #23 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 622
Originally Posted by azaz_ahamad View Post
No Wrong Ways
This Point Imprtent.
Data0
CMD
CLK
VCCQ
GND
Usb Insert ( VCC Only)
Most Importent:- Now All Conected BuT Storage Not Show In Emmc Tool..
Solution- Emmc Tool USB Port Plug & Unplug Again And Again Then Sacn
Finelly Show Storage 100%
Where Is VCCQ
Data0
CMD
CLK
VCCQ
GND
please tell me otherwise must need UMT ISP Hardware
Please Help Me
Old 05-27-2020, 07:40   #24 (permalink)
Member: 2669553
oppo A5 2020 CPH1933 isp pinout?
Old 07-13-2020, 10:25   #25 (permalink)
Member: 1314703
Thanks Meter: 9
Physical Details:
I'm having same problem on oppo A3s
Please helpooooooo
Umt team
All umt emmc users
The Following User Says Thank You to pedro gsm rev For This Useful Post:
Old 08-06-2020, 05:16   #26 (permalink)
Member: 1587904
Thanks Meter: 55
my question is Is umt emmc hardware tool works ok after modification with registers or i have to buy other tool for isp connection
planning to buy emmc isp hardware adaptor
Old 08-06-2020, 11:51   #27 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 471
vcc and vccq voltages are high not normal thay are over 3.5 i bought today havent tested with phones will try to connect phone and post results later
Old 08-22-2020, 08:59   #28 (permalink)
Crazy Poster
Member: 2422860
Thanks Meter: 3
Hello Team,
I found this in youtube. This man is using 150 ohms and 100ohm 5% tolerance resistor. Can anyone describe this schematic diagram of it. It would be helpful to those who are not able to find 150 ohms 1% tolerance resistor. Thank you in Advance!!!
Old 08-29-2020, 17:35   #29 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 450
meaning we cant use umt isp adapters without modification,,already ordered one,,so before delivery i needed a tutorial,,but am seeing modifications being made,,cant team make it be4 ,distrubition
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 09-28-2020, 18:48   #30 (permalink)
Member: 755814
Thanks Meter: 15
So which modification is the one that works, what are the voltages that should be output and what are the resistors to use, I have 3.0 volts in all the pins
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.28327 seconds with 7 queries
