05-11-2021, 02:56 | #1 (permalink) |
Junior Member Join Date: Oct 2019 Location: Venezuela
Member: 2932665 Status: Offline Thanks Meter: 1 | Write firmware Redmi 7a Failed Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM21) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_035]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : 8937, EMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [sec.dat] -> [sec] ...Done Writing [vbmeta.img] -> [vbmeta] ...Done Writing [vbmeta.img] -> [vbmetabak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [dummy.img] -> [apdp] ...Done Writing [dummy.img] -> [msadp] ...Done Writing [sbl1.mbn] -> [sbl1] ...Failed Operation Finished. any solution? |
05-11-2021, 09:07 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Try again and if problem persists, it may be issue with eMMC. If device is dead or hang on logo, then there are more chances of hardware issue. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
