Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 01-03-2020, 09:40   #1 (permalink)
Member: 509103
Thanks Meter: 40
Xiaomi A3 flash problem .After flash phone stay fastboot mode.
Operation : Multi Flash
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM78)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1A01000 [E1A01000] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Initializing Protocol...OK
Sending Loader [prog_firehose_ddr.elf]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Reading Auth Blob...OK
Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDM3Njg2RjM4MzI0NjZCNk M2RTczMzEzNDY3MzQzMzc5NkQ1MDYxNEM0QTMzNTE2OTQ3NDU3 Nz==
Requesting UMT Server for Auth Data...OK
Credits Left: 0
Authenticating...OK
Detecting Chip Type...OK
Using Alternate Method...
Hardware : E1A01000, UFS, 64 GB
LU Count : 6 [0x00DD4800] [0x00000800] [0x00000800] [0x00008000] [0x00100000] [0x00008000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [65536], Out: 1048576, Sector Size: 4096
Processing [rawprogram0.xml]
Writing [persist.img] -> [persist] ...Done
Writing [product.img ] -> [product_a]...Done
Writing [product.img ] -> [product_b]...Done
Writing [system.img ] -> [system_a]...Done
Writing [system_other.img ] -> [system_b]...Done
Writing [metadata.img ] -> [metadata]...Done
Writing [userdata.img ] -> [userdata]...Done
Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup0.bin] -> [BackupGPT] ...Done
Applying Patches................Done
Processing [rawprogram1.xml]
Writing [xbl.elf] -> [xbl_a] ...Done
Writing [xbl_config.elf] -> [xbl_config_a] ...Done
Writing [gpt_main1.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup1.bin] -> [BackupGPT] ...Done
Processing [rawprogram2.xml]
Writing [xbl.elf] -> [xbl_b] ...Done
Writing [xbl_config.elf] -> [xbl_config_b] ...Done
Writing [gpt_main2.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup2.bin] -> [BackupGPT] ...Done
Processing [rawprogram3.xml]
Writing [gpt_main3.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup3.bin] -> [BackupGPT] ...Done
Processing [rawprogram4.xml]
Writing [rpm.mbn] -> [rpm_a] ...Done
Writing [tz.mbn] -> [tz_a] ...Done
Writing [hyp.mbn] -> [hyp_a] ...Done
Writing [NON-HLOS.bin] -> [modem_a] ...Done
Writing [BTFM.bin] -> [bluetooth_a] ...Done
Writing [abl.elf] -> [abl_a] ...Done
Writing [dspso.bin] -> [dsp_a] ...Done
Writing [km4.mbn] -> [keymaster_a] ...Done
Writing [boot.img] -> [boot_a] ...Done
Writing [cmnlib.mbn] -> [cmnlib_a] ...Done
Writing [cmnlib64.mbn] -> [cmnlib64_a] ...Done
Writing [devcfg.mbn] -> [devcfg_a] ...Done
Writing [qupv3fw.elf] -> [qupfw_a] ...Done
Writing [vendor.img ] -> [vendor_a]...Done
Writing [vbmeta.img] -> [vbmeta_a] ...Done
Writing [dtbo.img] -> [dtbo_a] ...Done
Writing [imagefv.elf] -> [imagefv_a] ...Done
Writing [uefi_sec.mbn] -> [uefisecapp_a] ...Done
Writing [storsec.mbn] -> [storsec_a] ...Done
Writing [rpm.mbn] -> [rpm_b] ...Done
Writing [tz.mbn] -> [tz_b] ...Done
Writing [hyp.mbn] -> [hyp_b] ...Done
Writing [NON-HLOS.bin] -> [modem_b] ...Done
Writing [BTFM.bin] -> [bluetooth_b] ...Done
Writing [abl.elf] -> [abl_b] ...Done
Writing [dspso.bin] -> [dsp_b] ...Done
Writing [km4.mbn] -> [keymaster_b] ...Done
Writing [boot.img] -> [boot_b] ...Done
Writing [cmnlib.mbn] -> [cmnlib_b] ...Done
Writing [cmnlib64.mbn] -> [cmnlib64_b] ...Done
Writing [devcfg.mbn] -> [devcfg_b] ...Done
Writing [qupv3fw.elf] -> [qupfw_b] ...Done
Writing [vendor.img ] -> [vendor_b]...Done
Writing [vbmeta.img] -> [vbmeta_b] ...Done
Writing [dtbo.img] -> [dtbo_b] ...Done
Writing [imagefv.elf] -> [imagefv_b] ...Done
Writing [uefi_sec.mbn] -> [uefisecapp_b] ...Done
Writing [storsec.mbn] -> [storsec_b] ...Done
Writing [apdp.mbn] -> [apdp] ...Done
Writing [logfs_ufs_8mb.bin] -> [logfs] ...Done
Writing [storsec.mbn] -> [storsec] ...Done
Writing [gpt_main4.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup4.bin] -> [BackupGPT] ...Done
Processing [rawprogram5.xml]
Writing [gpt_main5.bin] -> [PrimaryGPT] ...Done
Writing [gpt_backup5.bin] -> [BackupGPT] ...Done
Resetting device...Done
Operation Finished.
QcFire Ver. 5.1
The Following 2 Users Say Thank You to godjy For This Useful Post:
Old 01-03-2020, 12:07   #2 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Possibly wrong firmware used.
Br,
UMT
The Following 2 Users Say Thank You to U.M.T For This Useful Post:
Old 01-03-2020, 13:33   #3 (permalink)
Member: 509103
Thanks Meter: 40
Same firmware, phone came in with no IMEI and after I flashed it got stuck in fastboot mode.
Old 01-03-2020, 14:09   #4 (permalink)
Titan_GSM's Avatar
Member: 2901996
Thanks Meter: 917
1st unlock bootlaoder if uh can.
  1. fastboot flashing unlock
  2. fastboot flashing unlock_critical
after booloader unlock flash twrp>flash recovery rom via twrp.
Old 01-03-2020, 14:56   #5 (permalink)
Member: 509103
Thanks Meter: 40
FAILED (remote: 'Flashing Unlock is not allowed')
fastboot: error: Command failed
oem is locked
The Following User Says Thank You to godjy For This Useful Post:
Old 01-03-2020, 17:39   #6 (permalink)
Member: 509103
Thanks Meter: 40
Does anyone know if there's free EDL flash tool for xiaomi, without authorization? A one-time buy would also do the trick.Thanks.
Old 01-04-2020, 09:25   #7 (permalink)
Member: 509103
Thanks Meter: 40
Now i want to flash with older version but server is offline
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM78)
Connecting to phone...OK
Waiting for response...OK
Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDM3Njg2RjM4MzI1MTQ2NU E3QTcyNTU0QTRENTk2MzUxMzI3NzcxMzc2QjY0NEY3NjQ1NEQ3 N0==
Requesting UMT Server for Auth Data...Server Offline
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Failed.
QcFire Ver. 5.1
Old 01-04-2020, 17:00   #8 (permalink)
U.M.T's Avatar
Member: 2465108
If device is clean, and Find Device is not ON, please try again after sometime.
Br,
UMT
Old 01-04-2020, 23:06   #9 (permalink)
Member: 2562737
Thanks Meter: 75
Type:
fastboot getvar current-slot
and post log here
Old 01-06-2020, 08:21   #10 (permalink)
Member: 509103
Thanks Meter: 40
current-slot: a
Finished. Total time: 0.000s
Old 01-06-2020, 18:09   #11 (permalink)
Member: 2562737
Thanks Meter: 75
current-slot: a
Type:
Old 01-07-2020, 08:32   #12 (permalink)
Member: 509103
Thanks Meter: 40
bootloader is locked
Old 01-07-2020, 09:16   #13 (permalink)
Member: 509103
Thanks Meter: 40
Again 10credits lost,again stay in fastboot mode
Port : Qualcomm HS-USB QDLoader 9008 (COM83)
Opening Port...OK
Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDM3Njg2RjM4MzI0NDU1ND k2QzU0NTQ3OTVBNDI2NDM5NjM2ODM1Njc3NzY4NTY2QjMxNTA1 MT==
Credits Left: 0
Authenticating...OK
Operation Finished.
QcFire Ver. 5.2
Old 01-07-2020, 10:58   #14 (permalink)
Member: 215919
Thanks Meter: 37
godjy Xiaomi A3 flash problem .After flash phone stay fastboot mode
risky format format chip make backups before you need to make edl mode flash
Old 01-07-2020, 10:58   #15 (permalink)
Member: 215919
Thanks Meter: 37
make format chip but take risky efs backup
Page generated in 0.31553 seconds with 8 queries
