01-17-2020, 00:41 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | xiaomi mi 8 platina dead after reset my acc. [Answered] before resetting my acc the xiaomi was bootloader unlock. I have flashed with several firmware and the problem persists, does not go into fastboot, just turn on the battery and turn it off. I did tests with another battery with full charge and it is the same error. I think it's a bootloader problem. Any ideas to fix this error? |
02-11-2020, 20:33 | #10 (permalink) |
No Life Poster Join Date: Dec 2013 Location: ecuador
Member: 2078045 Status: Offline Thanks Meter: 151 | Device : Xiaomi_No_Auth RedmiNote8_ginkgo Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM43) Driver Info : Lenovo Inc., leusbser.sys, 2.0.9.6 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [E1A01000] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38198FBDE6433FCE1D 25A7B0472 Initializing Protocol...OK Preparing Loader...Done Sending Loader [RedmiNote8_ginkgo]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.2 |
02-12-2020, 07:45 | #11 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
The Following User Says Thank You to U.M.T For This Useful Post: |
06-25-2020, 19:01 | #12 (permalink) | |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | Quote:
sorry to delay answering, I was quarantined and covid-19, I'm back and I would like you to help me finish turning on my xiaomi mi 8 lite platina. Here is the log of when I reset my account and it stayed like this, it is like the photo I left above. log: Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 128 GB LU Count : 1 [0x0E8F8000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi MI 8 Lite [platina] Software : xiaomi.eu, 9.10.31 [Thu Oct 31 10:41:01 GMT 2019] Android Ver. : 9 Patch Level : 2019-09-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.3 | |
06-25-2020, 20:17 | #13 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | First of all use latest version of QcFire. Secondly it seems to be BETA or Custom ROM (xiaomi.eu, 9.10.31). You need to try to find same and flash. Br, UMT |
06-26-2020, 20:54 | #14 (permalink) | |
Crazy Poster Join Date: Feb 2013
Member: 1885932 Status: Offline Thanks Meter: 7 | Quote:
07-09-2020, 01:24 | #15 (permalink) | |
I understand, the issue is that it does not start in fastboot or recovery, it just turns on the battery logo and then it turns off, I repeat everything that happened when I tried to remove my account with umt version 4.3 and then it remains as it is currently. My last log was when I performed the process of removing my account and then brick was left. | |
