01-18-2021, 23:34 | #1 (permalink) |
Crazy Poster Join Date: Sep 2015 Location: Bolivia
Member: 2466114 Status: Offline Thanks Meter: 15 | Help! Disable Screenlock Fail! Code: Operation : Disable Screen Locks Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_035]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...OK Detecting Chip Type...OK Hardware : 8937, EMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 8A [olivelite] Brand : Xiaomi Prod.Name : olivelite_eea Software : ZQL2116-olivelite-build-20191214170409, V11.0.2.0.PCPEUXM [Sat Dec 14 17:06:03 CST 2019] Android Ver. : 9 Patch Level : 2019-12-01 USERDATA : Normal For Normal userdata, you can use [Reset Locks] button. Disabling Screen Locks...Failed If system partition is manipulated, flash only system and try again. Operation Failed. QcFire Ver. 6.4 |
01-19-2021, 17:59 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,375 | Not all device and firmware are supported. If method introduced works with a firmware, it will disable, otherwise, it will not. We will try to add support for more devices whenever possible. Br, UMT |
