Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 05-23-2020, 19:02   #1 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,640
Thumbs up Xiaomi Redmi Note 8 ginkgo 9.0 MI account & FRP remove done [Success Report]
1st TIME
Operation	: Multi Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port	: Qualcomm HS-USB QDLoader 9008 (COM45)
Driver Info	: Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID	: E1A01000 [SDM665] 00007200
OPK_DATA	: 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7
Initializing Protocol...OK
Sending Loader [prog_emmc_firehose_Sm6125_ddr.elf]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Reading Auth Blob...OK
Blob	: NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDRCNDU1MzM5NEU0NTQzNDQ1NTM0NDI3NjMzMzMzNzMwNjI0QzY5NEY1ODRCNTY3MTc5MzQ0MT==
Requesting UMT Server for Auth Data...OK
Credits Left: 0
Authenticating...OK
Detecting Chip Type...OK
Hardware	: SDM665, eMMC, 64 GB
LU Count	: 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info	: In: 65536 [65536], Out: 1048576, Sector Size: 512
Processing [rawprogram0.xml]
File gpt_main0.bin is missing from patch.
Resetting device...Done
Operation Finished.
QcFire Ver. 5.6
2nd SUCCESS
Operation	: Flash
Blob	: NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDRCNDU1MzM5NEU3ODMwNzE2QzY4NTE3NjRENzIzMDc5NUEyRDU4NDI0RDMyNkU1ODRGMzU2Nz==
Credits Left: 0
Authenticating...OK
Writing [Redmi_Note_8_FRP.bin] -> [FRP] ...Done
Writing [Mi_Account.img] -> [Redmi_Mi_Account] ...Done
Operation Finished.
QcFire Ver. 5.6
IMPORTANT INFORMATION
The Following 3 Users Say Thank You to yuranc8 For This Useful Post:
Old 05-23-2020, 19:09   #2 (permalink)
Member: 2754756
Thanks Meter: 37
No relock after this?
Enviado desde mi SM-A307G mediante Tapatalk
Old 05-23-2020, 20:55   #3 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,640
No sir u can try and post result
Old 05-23-2020, 20:56   #4 (permalink)
Member: 1120289
Thanks Meter: 148
Please how you do that,tell me more
Envoyé de mon SM-C7010 en utilisant Tapatalk
Old 05-24-2020, 06:13   #5 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,640
Hello got REDMI NOTE 8 INDIA, cant get LTE anyway to fix ? maybe flash other ROM
Old 06-16-2020, 17:23   #6 (permalink)
skyulock's Avatar
Member: 757064
Sonork: 11111111
Thanks Meter: 365
what is solution to this one .
Operation : Reset FRP
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM173)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0
Opening Port...OK
Invalid response from device!
Found Port : Qualcomm HS-USB QDLoader 9008 (COM173)
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0MjcwN0EzNTM4NEQzOTc0Nz U0MzZDNTU0RjQ2Njc0RjJENDY3NzMxNTE0QjU4MzM1MTc0NjM2 Nz==
Getting Auth Data...Failed! Access denied!
Please check if your Mi Service Account is authorized .
Or please restart Auth App.
Slow Internet/Mi Server may also cause this.
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 5.6
Old 06-16-2020, 18:10   #7 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,640
Hello at first you need AUTH credits and special files for FRP as you can see my 2nd logs i flashed few files!
Good luck ��
Old 06-17-2020, 06:49   #8 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Good luck ��
If possible please share those special files.
Thanks.
Old 06-17-2020, 08:51   #9 (permalink)
skyulock's Avatar
Member: 757064
Sonork: 11111111
Thanks Meter: 365
Thanks.
this is file https://drive.google.com/file/d/1PCP...PLJe1pbKI/view
Old 06-17-2020, 09:54   #10 (permalink)
skyulock's Avatar
Member: 757064
Sonork: 11111111
Thanks Meter: 365
error
Opening Port...OK
Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0MjcwN0EzNTM4NEQ2QjVGND E0MTc1MkQ1NjU5N0E0ODcwNzQ2Nzc1NzI0NjM3Nzk2OTc5NTc2 Nz==
Requesting UMT Server for Auth Data...Connection Error!
Operation Finished.
QcFire Ver. 5.6
Old 06-17-2020, 10:07   #11 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,640
hello sir PM with ANYDESK ID and remove phone and battery for a while
Old 06-17-2020, 10:23   #12 (permalink)
skyulock's Avatar
Member: 757064
Sonork: 11111111
Thanks Meter: 365
bro help me
Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0MjcwN0EzNTM4NEQ3MTQ2Nk I0MjZGNzA1NTMyMzk2MzREMkQ0MzVGNkEyRDM4NkQyRDc1Nzg2 Nz==
Requesting UMT Server for Auth Data...Auth Denied!
Please make sure Find Device is OFF
Detecting Chip Type...Failed
Operation Finished.
QcFire Ver. 5.6
Old 06-18-2020, 07:38   #13 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
Originally Posted by skyulock View Post
file was password protected. & found this pass working
Redmi_note_8_FRP+MI_Account_Done_By-KAILASH
Old 06-18-2020, 11:16   #14 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 1,640
Hello use Jtag to remove FRP and Mi account
FMP (Find my phone On) not allow to flash or service other operation
Old 06-20-2020, 07:10   #15 (permalink)
Member: 2520958
Thanks Meter: 7
connect to wifi and relock again
The Following 2 Users Say Thank You to alexjaime For This Useful Post:
Page generated in 0.27128 seconds with 8 queries
