05-23-2020, 19:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Xiaomi Redmi Note 8 ginkgo 9.0 MI account & FRP remove done [Success Report] Code: Operation : Multi Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM45) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sm6125_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDRCNDU1MzM5NEU0NTQzNDQ1NTM0NDI3NjMzMzMzNzMwNjI0QzY5NEY1ODRCNTY3MTc5MzQ0MT== Requesting UMT Server for Auth Data...OK Credits Left: 0 Authenticating...OK Detecting Chip Type...OK Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 1048576, Sector Size: 512 Processing [rawprogram0.xml] File gpt_main0.bin is missing from patch. Resetting device...Done Operation Finished. QcFire Ver. 5.6 Code: Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM45) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sm6125_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0NDRCNDU1MzM5NEU3ODMwNzE2QzY4NTE3NjRENzIzMDc5NUEyRDU4NDI0RDMyNkU1ODRGMzU2Nz== Requesting UMT Server for Auth Data...OK Credits Left: 0 Authenticating...OK Detecting Chip Type...OK Hardware : SDM665, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [65536], Out: 1048576, Sector Size: 512 Writing [Redmi_Note_8_FRP.bin] -> [FRP] ...Done Writing [Mi_Account.img] -> [Redmi_Mi_Account] ...Done Resetting device...Done Operation Finished. QcFire Ver. 5.6 |
The Following 3 Users Say Thank You to yuranc8 For This Useful Post: |
06-16-2020, 17:23 | #6 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | what is solution to this one . Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM173) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Opening Port...OK Invalid response from device! Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM173) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sm6125_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0MjcwN0EzNTM4NEQzOTc0Nz U0MzZDNTU0RjQ2Njc0RjJENDY3NzMxNTE0QjU4MzM1MTc0NjM2 Nz== Getting Auth Data...Failed! Access denied! Please check if your Mi Service Account is authorized . Or please restart Auth App. Slow Internet/Mi Server may also cause this. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.6 |
06-17-2020, 08:51 | #9 (permalink) |
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | |
06-17-2020, 09:54 | #10 (permalink) |
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | error Port : Qualcomm HS-USB QDLoader 9008 (COM173) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A01000 [SDM665] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sm6125_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0MjcwN0EzNTM4NEQ2QjVGND E0MTc1MkQ1NjU5N0E0ODcwNzQ2Nzc1NzI0NjM3Nzk2OTc5NTc2 Nz== Requesting UMT Server for Auth Data...Connection Error! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.6 |
06-17-2020, 10:23 | #12 (permalink) |
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | bro help me Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sm6125_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ5NkY0MjQxNDE0MjcwN0EzNTM4NEQ3MTQ2Nk I0MjZGNzA1NTMyMzk2MzREMkQ0MzVGNkEyRDM4NkQyRDc1Nzg2 Nz== Requesting UMT Server for Auth Data...Auth Denied! Please make sure Find Device is OFF Detecting Chip Type...Failed Auth Enabled Device! You need Mi Auth Account to service! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 5.6 |
06-18-2020, 11:16 | #14 (permalink) |
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Requesting UMT Server for Auth Data...Auth Denied! Please make sure Find Device is OFF Hello use Jtag to remove FRP and Mi account FMP (Find my phone On) not allow to flash or service other operation |
