GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Ultimate Multi Tool Box (https://forum.gsmhosting.com/vbb/f970/)
-   -   y1 flashing error (https://forum.gsmhosting.com/vbb/f970/y1-flashing-error-2698034/)
vsy 09-29-2019 07:19
y1 flashing error
Operation : Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM36)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1B00600 [8937] 00000000
OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B
Initializing Protocol...OK
Sending Loader [prog_emmc_firehose_8937_ddr.mbn]...Done
Executing Loader...OK
Detecting Chip Type...OK
DebugData : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTM2KT ==
Using Alternate Method...
Error getting Payload Information!
Error Log : UXVhbGNvbW0gSFMtVVNCIFFETG9hZGVyIDkwMDggKENPTTM2KT ==
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 4.5
phone condition dead charging led only blinging
put usb cable go to auto edl mode
sagarjais 09-29-2019 07:24
Originally Posted by vsy (Post 13840368)
Operation : Flash
Operation Finished.
QcFire Ver. 4.5
what was phone's condition before flashing?
select loader manually from firmware..
or try to flash with miflash
then post results
Best Regards
Sagar Jaiswal
Press Thanks If Helped
Deni's 09-29-2019 08:12
Operation : Flash
Operation Finished.
QcFire Ver. 4.5
hardware problem bro...
vsy 09-29-2019 08:13
then post results
Best Regards
Sagar Jaiswal
1.what was phone's condition before flashing?
phone codition dead\
2.select loader manually from firmware..
same error
3.miflash then post results
[12:39:34 PM COM36]:MiFlash 2017.4.25.0
[12:39:34 PM COM36]:[COM36]:start flash.
[12:39:34 PM COM36]:received hello packet
[12:39:34 PM COM36]:download programmer D:\ugg_global_images_V9.1.2.0.NDKMIEI_20171122.000 0.00_7.1_global_d8438062ed\ugg_global_images_V9.1. 2.0.NDKMIEI_20171122.0000.00_7.1_global\images\pro g_emmc_firehose_8937_ddr.mbn
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 0,length 52
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 52,length 288
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 4096,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 8192,length 2632
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 396480,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 400576,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 404672,length 2152
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 406824,length 2856
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 12288,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 16384,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 20480,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 24576,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 28672,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 32768,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 36864,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 40960,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 45056,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 49152,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 53248,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 57344,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 61440,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 65536,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 69632,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 73728,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 77824,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 81920,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 86016,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 90112,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 94208,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 98304,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 102400,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 106496,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 110592,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 114688,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 118784,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 122880,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 126976,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 131072,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 135168,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 139264,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 143360,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 147456,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 151552,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 155648,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 159744,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 163840,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 167936,length 4096
[12:39:34 PM COM36]:sahara read data:imgID 13, offset 172032,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 176128,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 180224,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 184320,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 188416,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 192512,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 196608,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 200704,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 204800,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 208896,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 212992,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 217088,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 221184,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 225280,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 229376,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 233472,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 237568,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 241664,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 245760,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 249856,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 253952,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 258048,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 262144,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 266240,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 270336,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 274432,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 278528,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 282624,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 286720,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 290816,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 294912,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 299008,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 303104,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 307200,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 311296,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 315392,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 319488,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 323584,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 327680,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 331776,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 335872,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 339968,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 344064,length 360
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 344424,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 348520,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 352616,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 356712,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 360808,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 364904,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 369000,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 373096,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 377192,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 381288,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 385384,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 389480,length 4096
[12:39:35 PM COM36]:sahara read data:imgID 13, offset 393576,length 2904
[12:39:35 PM COM36]:sahara read end imgID:13 status:0
[12:39:35 PM COM36]:Send done packet
[12:39:35 PM COM36]:file D:\ugg_global_images_V9.1.2.0.NDKMIEI_20171122.000 0.00_7.1_global_d8438062ed\ugg_global_images_V9.1. 2.0.NDKMIEI_20171122.0000.00_7.1_global\images\pro g_emmc_firehose_8937_ddr.mbn transferred successfully
[12:39:37 PM COM36]:send nop command
[12:39:37 PM COM36]:send command:<?xml version="1.0" ?><data><nop verbose="0" value="ping"/></data>
[12:39:38 PM COM36]:write time out try agian 1
[12:39:40 PM COM36]:write time out try agian 2
[12:39:41 PM COM36]:write time out try agian 3
[12:39:43 PM COM36]:write time out try agian 4
[12:39:44 PM COM36]:write time out try agian 5
[12:39:46 PM COM36]:write time out try agian 6
[12:39:47 PM COM36]:write time out try agian 7
[12:39:49 PM COM36]:write time out try agian 8
[12:39:51 PM COM36]:write time out try agian 9
[12:39:52 PM COM36]:write time out try agian 10
[12:39:54 PM COM36]:write time out try agian 11
[12:39:55 PM COM36]:write time out try agian 12
[12:39:57 PM COM36]:write time out try agian 13
[12:39:58 PM COM36]:write time out try agian 14
[12:40:00 PM COM36]:write time out try agian 15
[12:40:01 PM COM36]:write time out try agian 16
[12:40:03 PM COM36]:write time out try agian 17
[12:40:04 PM COM36]:write time out try agian 18
[12:40:06 PM COM36]:write time out try agian 19
[12:40:07 PM COM36]:write time out try agian 20
[12:40:09 PM COM36]:write time out try agian 21
[12:40:10 PM COM36]:write time out try agian 22
[12:40:12 PM COM36]:write time out try agian 23
[12:40:13 PM COM36]:write time out try agian 24
[12:40:15 PM COM36]:write time out try agian 25
[12:40:16 PM COM36]:write time out try agian 26
[12:40:18 PM COM36]:write time out try agian 27
[12:40:19 PM COM36]:write time out try agian 28
[12:40:21 PM COM36]:write time out try agian 29
[12:40:22 PM COM36]:write time out try agian 30
[12:40:24 PM COM36]:write time out try agian 31
[12:40:25 PM COM36]:write time out try agian 32
[12:40:27 PM COM36]:write time out try agian 33
[12:40:28 PM COM36]:write time out try agian 34
[12:40:30 PM COM36]:write time out try agian 35
[12:40:31 PM COM36]:write time out try agian 36
[12:40:33 PM COM36]:write time out try agian 37
[12:40:34 PM COM36]:write time out try agian 38
[12:40:36 PM COM36]:write time out try agian 39
[12:40:37 PM COM36]:write time out try agian 40
[12:40:39 PM COM36]:write time out try agian 41
[12:40:40 PM COM36]:write time out try agian 42
[12:40:42 PM COM36]:write time out try agian 43
[12:40:43 PM COM36]:write time out try agian 44
[12:40:45 PM COM36]:write time out try agian 45
[12:40:46 PM COM36]:write time out try agian 46
[12:40:48 PM COM36]:write time out try agian 47
[12:40:49 PM COM36]:write time out try agian 48
[12:40:51 PM COM36]:write time out try agian 49
[12:40:52 PM COM36]:write time out try agian 50
[12:40:54 PM COM36]:write time out try agian 51
[12:40:54 PM COM36]:error:The write timed out.
[12:40:54 PM COM36]:[12:40:54 PM COM36]:error:The write timed out.
[12:40:55 PM COM36]:flashSuccess False
[12:40:55 PM COM36]:isFactory False CheckCPUID False
[12:40:55 PM COM36]:before:flashSuccess is False set IsUpdate:True set IsDone True
[12:40:55 PM COM36]:after:flashSuccess is False set IsUpdate:false set IsDone true
sagarjais 09-29-2019 08:41
seems that it can be hw issue...
wait for other dev's reply
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.13967 seconds with 6 queries
