01-07-2019, 20:10 | #1 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Pakistan/Canada/UK
Member: 2769072 Status: Offline Thanks Meter: 126 | ZTE Axon A1R Frp Failed Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM27) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1807B00 [8974] 00000400 OPK_DATA : A73B09776FFC7672832960646DFE2F1524AB6B799F813BF9C5 91715A53DDFC73 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8974_008]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8974, eMMC, 32 GB LU Count : 1 [0x03A3C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : ZTE A1R [msm8974] Software : A1RV1.1.0B08, 20160707.005703 [Thu Jul 7 01:00:59 CST 2016] Android Ver. : 6.0.1 Patch Level : 2016-06-01 Resetting FRP Lock...Failed Operation Failed. QcFire Ver. 3.5 |
01-08-2019, 16:34 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Can you please try FTM Method in UMT GSM and post result? And if possible please read gpt main and backup and send to us. Br, UMT |
05-21-2021, 09:59 | #3 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1807B00 [8974] 00000400 OPK_DATA : A73B09776FFC7672832960646DFE2F1524AB6B799F813BF9C5 91715A53DDFC73 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8974_008]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8974, EMMC, 32 GB LU Count : 1 [0x03A3C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : ZTE A1R [msm8974] [billy] Brand : ZTE Prod.Name : P897A10_ROGERS Software : A1RV1.1.0B08, 20160707.005703 [Thu Jul 7 01:00:59 CST 2016] Android Ver. : 6.0.1 Patch Level : 2016-06-01 Resetting FRP Lock...Failed Operation Failed. QcFire Ver. 6.5 |
05-21-2021, 10:16 | #4 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Port : COM182 : ZTE Handset Diagnostic Interface (COM182) Baud Rate : 921600 Device : ZTE Axon A1R Operation : FRP Reset Opening Port... OK Reading Phone Information... OK Compile : Jul 7 2016 00:25:01 Release : Jan 24 2016 23:00:00 Hw Ver. : AAAAANAZ Build : 9A1RV1.1.0B08 IMEI : 868704020070817 WIFI Addr : 000000000000 BT Addr : 000000000000 Resetting FRP Lock... OK Rebooting Device... OK You may now add your account and Reset Factory Setting Port Closed. Operation Finished. Elapsed Time: 00:07 [Module Ver. 5.5] Log Saved to Logs\210521_141432.log Still asking for Gmail ... how to Fix ??? |
