10-06-2022, 00:55 | #1 (permalink) |
Product Supporter Join Date: Jan 2021 Location: Jordan Age: 39
Member: 2979261 Status: Offline Thanks Meter: 101 | iPad A7 [SN+WIFI+BT] ➢ Premium Service |High Success| - Fresh Serials - Service Description: The service activation code is only used for iPad repairing and hard-solving iCloud/replacement hard drive code writing service, not iPhone. Submission method: Please enter "A7" in the field of order submission, and the order will be issued automatically. Reply template: DQWNQABCD198 WiFi: 25F3877E0475 BT: 25F3877E076 data support: A8 is suitable for: (/A8/A9/A10/A11/CPU's IPAD solution ID) A7 is suitable for: (IPAD5 generation of A7CPU, mini 2, mini 3, Mini 4 , Air 2 ) A5 applies to: (A5/A6/A6X) Other models are not supported. High Success Mini 4 , ipad 5 generation , Air 1 , Air 2, ipad 6th ( ios 15 ) Supported There is No refund if not active Matters needing attention: 1. After the service activation code is issued, the ID activation lock switch is guaranteed for 24 hours, and it will not be returned after 24 hours; 2. In case of failure to activate, please follow the steps below to troubleshoot: 1. Check whether the serial number, WiFi address, and Bluetooth address are incorrectly written; 2. Whether the device is a 4G version, if it is a 4G version, cut off the 4G resistor and try again; 3. Re-flash to the latest IOS system; 4. Remember that the IOS12 system needs to be activated with iTunes or WiFi. If activated with Ace or third-party tools, it will not be activated. Currently, some iPads belonging to the previous line can use the A8 code to activate. But with ios 14.4, some ipads can not use serial a8. required to use a7 code. So if the iPad does not activate with a8 code. I will check it again. If I can still be active, they must use a7 code. if the a7 code is still inactive then there isn't any code that can be activated. ios 14 is difficult DUAL NOT SUPPORTED Dual Not Supported Dual Not Supportedd Dual Not Supported he service is now fast and stable Best prices for delegates Special prices for individuals We welcome you for your inquiries 24 hours 📥 Telegram Channel Link - https://t.me/GSMJordanEN 📜 WhatsApp : +962788860606 🌍 Facebook : @gsmjordanjo 📧 Email support: [email protected] 🔁 website: gsmjordan.com |
