05-23-2022, 22:39 | #1 (permalink) |
Product Supporter Join Date: Jan 2021 Location: Jordan Age: 39
Member: 2979261 Status: Offline Thanks Meter: 101 | MetroPcs USA - Devices Mobile App Unlock (Premium) Verification time is only 3 Days After 3 Days No verification No Arguments Service works Batch basis only , Batch Date wil be announced in Service Tab Advertised Time is approximate time not a guranteed delivered time,how ever we make efforts to complete the order in respected time earlier or within time frame. Warning: Do not use this service to Unlock IMEI from T-Mobile USA as you will receive a NOT WORKING CODE and you won't be able to claim for a refund ! T-Mobile USA is not supported, only MetroPCS is supported so do not waste the time of our supplier sending Junk IMEI as you will end wasting your money. Must Read Before Submit Imeis:- We only refund for "NOT ELIGIBLE FOR UNLOCK" issue, we will not refund any complaint about "COMMUNICATION ERROR" Reboot Error" or Any other error. It's mandatory to check before ordering if your phone have "COMMUNICATION ERROR" issue, if the answer is yes then you can try to fix this error by performing a hard reset on your phone, or upgrading his firmware. Again make sure your phone can communicate with "Device Unlock App" server BEFORE place your order. *Once process returns completed turn on app, and device will be officially unlocked. IN Process imei Not Possible to Cancel in case of Not Unlock issue please Submit a ticket here https://gsmjordan.com/settings/ticket with imei only No video required we will update your after check with supplier asap and if supplier required for a video proof we will ask you there on ticket provide us video as supplier required. Note: How to make video Please Write Code provided in ticket on a paper show code in video imei and error on screen very clearly upload at youtube.com click on publish send imei and video link. Error Message Information / Troubleshooting Device not recognized by your service provider. Please call customer care. Rooting your device will disable the unlock application Download the latest Metro software to continue Data corrupted during transfer. Please try again.Error during data transfer. Please try again. Ensure the device has stable mobile signal Restart the device and try again Server not responding. Please try again later. No response is received from the server Try using an alternate internet connection Failure in processing the request. Please reboot device and try again. Ensure that your device has sufficient memory Restart the device and try again Unlock Failed: Unlock Approved : Mobile Device is permanently unlocked Solution 1: Perform a hard reset and attempt a second unlock. Solution 2: Perform 2 consecutive hard reset without attempting the unlock and once the second hard reset has been performed attempt the unlock again. Make sure phone has latest Android version available for that device. No internet connection available. Please try again when internet connection is available. No internet connection is available: Device is not connected to 3G/4G LTE. A non-compatible SIM card is being used, Unable to connect to the server at this time. Please try back again later. Update the app using the Play Store Attempt the unlock using the mobile network. Unlock Failed: This mobile wireless device is not eligible for unlock. For Device Unlock eligibility details, please go online or contact Customer Care. The device is not eligible for unlock. (Order the Unlock Service from UnlockBase) Unlock Failed : System maintenance error, try again later. System Maintenance is currently underway Wait and try again later Failure in applying the unlock settings. Please try again. The device must be connected to the mobile network (including domestic and international roaming) Disconnect from Wi-Fi and try again. fast service prompt service All steps are included in the service Best Prices For Bulk Users 📜 WhatsApp : +962788860606 🌍 Facebook: @gsmjordanjo 📧 Email support: [email protected] 🔁 website: gsmjordan.com |
