12-14-2022, 22:57 | #1 (permalink) |
Product Supporter Join Date: Jan 2021 Location: Jordan Age: 39
Member: 2979261 Status: Offline Thanks Meter: 101 | Samsung Carrier bypass by Perseus team {Only T-MOBILE}0 If you neeed to remove KG plus Unlock the T-Mobile it work only if your phone in download mode show kg Status: normal and locked Perseus Bypass Official Guide of Install and Instructions Final Revision. STEP 1: PREREQUISITES TO BE ABLE TO BYPASS!! OS Support: ANDROID 11 and ANDROID 12 If you are on Android 10 and want to update, please BEFORE using your QR code use this one that’s meant to update your device to Android 11 at least. Here is how you do that update ONLY for android 10. https://*********/eGfyWYZsfWg Scan the QR for OTA upgrade, then tap next until you reach the google privacy thing, once there don’t keep going just wait for that big qr code, now with power button and vol down as you were to shut off the device tap repeat the back button and you are now at the home screen, from there just go to settings, connect to Wi-Fi (reconnect) and download your ota straight from Samsung!- ANDROID 10 NOT SUPPORTED Please follow the guidelines on the document labeled instructions before doing a bypass. 1) Check by entering recovery mode (if you don’t know how watch this video) https://www.youtube.com/watch?v=D51xCQtPFw8 2) Check Download mode before buying (if you don’t know how to enter download mode watch this video) https://www.youtube.com/watch?v=4wsafWtXT0c Values MUST be like the ones below. - Samsung Official - FRP OFF (you can remove it if it’s on) - KG Status: Locked/Checking/Prenormal if purchasing or other products for non-locked devices. - OEM Lock: ON - Warranty Void or Warranty Bit: 0 3) If during the scan/install process you see IT Code error that ́s related to the integrity of the policies or user intervention during this. Or that you currently have Android 10. You need to update to at least Android 11 One UI 3 to bypass a device. *Follow the video as-is and you will never have issues* The service is now fast and stable Best prices for delegates Special prices for individuals We welcome you for your inquiries 24 hours 📥 Telegram Channel Link - https://t.me/GSMJordanEN 📜 WhatsApp : +962788860606 🌍 Facebook : @gsmjordanjo 📧 Email support: [email protected] 🔁 website: gsmjordan.com |
