Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > ASUS
ASUS ASUS Devices
Old 10-31-2014, 11:26   #1 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 12,002
ASUS-FAQ (Update Manual/Informatione/Flash/Wipe ETC)
ASUS-FAQ }-Before post read 1st-{ Update/Flash/Wipe ETC manual/Information
HI ,
let's we keeps all kind ASUS information on this thread , I seen on forum some user face problems . So i want to inform them tips about asus . Unfortunately, We have no ASUS section on this forum . I already request for the section . Hopefully as soon as will be add ASUS section in this forum . Then we will move to ASUS section . Until become ASUS section we use Android Section
Lets me start using Question and answer
Q
: Where to download ASUS firmware ?
A: You can download from ASUS official side , Here is it
Example : I need ASUS T00G , Check Here
Q: How to know the device model?
A: Path: Settings->About-> Model number
Q
:How to know the device software version?
A:Path: Settings->About-> software information->Build number
Q
: What is ASUS SKU ?
A: Simply we can call its language pack of software version
Q
: Can i use any SKU ?
A: No , Software update cannot transfer the software SKU and downgrade the software version and Wrong SKU may cause update failure, please update the same SKU version only !
Example: WW->WW, CN->CN, TW->TW, CHT->CHT.
Q: How to know my phone SKU ?
A: Go to [Settings] -> [About tablet] -> Build number
Example : WW_epad-9.X.X.X._2012xxxx, where “WW” means SKU.
Q
: Can I Update Low Version To Direct Latest Version ?
A: Yes you can but if you try direct update , You can get error on update , Cases some version require another update
Example - Your phone have 1.12 You need update 2.XX , This case you need update V1.18 Update 1st then you can update 2XX
Q
: How to know my phone require another update 1st then i can update to latest ?
A: Before download Firmware read 1st You you will see like below "
Note: Please make sure update software version V1.18.40.12 first before update to software version V2.19.40.18
This case you must update 1st V1.18 then you can update V2.19
If anything missing just thread report , Mod can be add your Information
Don't Copy to other forum or side , If you want copy must write who originally posted Also Write Copy From GSMHOSTING
__________________
Use the Forum according to Rules...!
Each section has Rules to follow
Cordially,
AzimBahar/ParvezAhmed
The Following 18 Users Say Thank You to aZimBahar For This Useful Post:
Old 10-31-2014, 11:34   #2 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
How To Update ASUS Phone
Q: How To Update ASUS Phone ?
A: You can update With SD/Internal mmc Card also have another way but i cant share until test
You can Download Manual From Support Side or fellow me !
How To Update With SD Card/Internal mmc
Extract Your Firmware
Copy Your zip file - XX-ASUS_T00X-XX-X.XX.XX.XX-user.zip To Phone
Disconnect Usb cable From Phone
You Will Get A Notification Or Down the System Notification bar
Select System Update File Detect....
Click OK
Click Again OK
Phone Will Be Booted On Update...
Wait For Finish , Whenever Finish Its Will Be Reboot
Enjoy !
__________________
Cordially,
The Following 8 Users Say Thank You to aZimBahar For This Useful Post:
Old 11-01-2014, 03:53   #3 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Update manual - Device_Firmware_Update_SOP_V1_1
AzimBahar/ParvezAhmed.NET
The Following 3 Users Say Thank You to aZimBahar For This Useful Post:
Old 11-12-2014, 12:06   #4 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Tutorial }- How to Unbrick Zenfone 5 and Zenfone 6
http://forum.gsmhosting.com/vbb/f606.../#post10673797
The Following 6 Users Say Thank You to aZimBahar For This Useful Post:
Old 12-01-2014, 07:36   #5 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
How To Identify ASUS SKU From hang Phone ?
How To Identify ASUS SKU From hang Phone :
  • Turn Off The Phone
  • Go to Bootloader Mode Using Bootloader Key (Its Depend On Your Model ) Just Search On Google ! Mosly ASUS Bootloader Mode Come Using Volume Up+Power ( Continue Press and Hold both button Until Come Bootloader Mode
  • You Can Check SKU & Version To Bootloader Mode !
Screenshot By AzimBahar/ParvezAhmed.NET
The Following 4 Users Say Thank You to aZimBahar For This Useful Post:
Old 12-01-2014, 08:25   #6 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
How To Update ASUS With CMD / ADB Mode ?
  • Entry Phone To Recovery Mode
  • Select "apply update from ADB"
  • Connect Phone To PC & Install Driver
  • Now Extract Your Firmware (Download)
  • Rename (XXXXXuser.zip ) Your File to Simple Word ( Like azimbahar.zip )
  • Now Copy file to your to ADB Folder
  • Now Open CMD (Open command prompt(In Programs>Accesories or click Start>Run>"type" cmd)
  • Type "adb sideload azimbahar.zip"
  • Wait For 100%
  • After You can Wipe Phone & Reboot
  • Enjoy !
Tested Report
Note - If Update fails , Read #1 : http://forum.gsmhosting.com/vbb/f606...ation-1874625/ Details !
The Following 17 Users Say Thank You to aZimBahar For This Useful Post:
Old 01-05-2015, 08:35   #7 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Originally Posted by biddut1979 View Post
Dear/ mr ..::One-Man::..
Asus Zenfone 6 wifi and bluetooth option hiden ant work . how can i solve this problem plx tell me .
sorry for my poor english
Just today Back from break , Did you try wipe ?
The Following 2 Users Say Thank You to aZimBahar For This Useful Post:
Old 02-01-2015, 03:41   #8 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Simply Unbrick Asus :
[B]Warning ...
Before try Unbrick Zenfone 5 and Zenfone 6
This Case , If your phone like this Brick
http://forum.gsmhosting.com/vbb/redi...0c94680569245e
Its avileable to Entry recovery Mode , Just Off your phone and entry recovery mode , Then try Hardreset And Check , If its still Brick Then Install firmware to Recovery mode !
I have done Unbrick Zenfone 5 and Zenfone 6 both via recovery mode !
So Attension before doing
Tested on many ASUS !
The Following 7 Users Say Thank You to aZimBahar For This Useful Post:
Old 02-04-2015, 05:42   #9 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Zenfone 4 (A400CG) Bootloop Solution Share By AzimBahar
Zenfone 4 (A400CG) Bootloop Solution :
How To Do :
  • 1st Download RAW file (available on Google search)
  • Copy RAW file to sd card
  • Put sd card to phone
  • Entry Droidboot mode
  • Choose SD Download
  • that's it !
How to enter Droidboot on Zenfone 4 A400Cg
  1. Make sure the device is turned off, and there is more than 10% of battery life available.
  2. Press the combination keys of “Power key + Volume up Key” for 3~5 seconds, release when you see the an Android icon, to enter Update (Droidboot) Mode
Azimbahar/ParvezAhmed.NET
Old 02-19-2015, 11:26   #10 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
How To Update ASUS ASUS Fonepad 7 (K012)
How To Update ASUS ASUS Fonepad 7 (K012):
  • Download firmware (READ #1)
  • Rename file name to "K012_sdupdate"
  • Copy file to SD card
  • Entry phone to bootloader mode
  • Select SD Update
  • That's it
Bootloader Mode : Volume up +Power Together Until come bootloader menu
Enjoy My method
Old 02-24-2015, 12:08   #11 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
http://forum.gsmhosting.com/vbb/f606...lease-1919755/
Old 03-05-2015, 22:08   #12 (permalink)
Member: 552244
Sonork: 100.1578827
Thanks Meter: 180
  • Select SD Update
  • That's it
Enjoy My method
but no sd Update menu in bootloader mode
The Following 2 Users Say Thank You to .::MD_AKTER::. For This Useful Post:
Old 03-29-2015, 14:58   #13 (permalink)
Member: 2095217
Thanks Meter: 3
uodate from recovery mode
The Following 2 Users Say Thank You to saikoo2008 For This Useful Post:
Old 04-21-2015, 06:36   #14 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Complete log writing boot,fastboot,recovery .IMG for Unbrick Asus
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\azimbahar>cd \
C:\>fastboot flash recovery recovery.img
target reported max download size of 1329861973 bytes
sending 'recovery' (12185 KB)...
OKAY [  1.823s]
writing 'recovery'...
(bootloader) secure device
(bootloader) signed image
OKAY [  2.049s]
finished. total time: 3.878s
C:\>fastboot flash fastboot fastboot.img
sending 'fastboot' (12440 KB)...
OKAY [  1.808s]
writing 'fastboot'...
OKAY [  2.088s]
finished. total time: 3.901s
C:\>fastboot flash boot boot.img
sending 'boot' (9210 KB)...
OKAY [  1.453s]
writing 'boot'...
OKAY [  1.759s]
finished. total time: 3.218s
The Following 11 Users Say Thank You to aZimBahar For This Useful Post:
Old 04-26-2015, 11:32   #15 (permalink)
Member: 1663119
Sonork: iffi3
Thanks Meter: 213
plz help me i hav asus K012 STUCK on logo here is my detail or tab plz tell me can i use this file for my tab or can u give me the link or my tab...thx
[IMG][/IMG]
The Following 6 Users Say Thank You to iffipower For This Useful Post:
Page generated in 0.25479 seconds with 8 queries
