ASUS ASUS Devices |
10-23-2016, 03:24 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | Forgotten pattern lock of asus zenfone 2 z00d AT&T 1. reboot 2. update frm adb. 3. update frm microSD. how to do plz help thx |
06-16-2019, 13:18 | #4 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Ghana - Mozano
Member: 2203321 Status: Offline Thanks Meter: 46 | JOBATECH ASUS FLASHING PROCEDURE MADE SIMPLE 1. Install Asus Flash Tool and drivers 2. Put phone in fastboot mode and connect to PC 3. Open Asus Flash Tool and load firmware to flash Alternative If flashing fails, 1. Extract boot and droidboot from the zipped firmware 2. Place firmware and extracted boot & droidboot image file in Asus Flash Tool location "C:\Program Files\ASUS\ASUS Flash Tool\Google" 3. Press Shift key and right-click in the window ("C:\Program Files\ASUS\ASUS Flash Tool\Google") * Select open command window here Type the following: fastboot devices and hit Enter. Your device should appear. fastboot flash fastboot droidboot.img Wait till it's done. fastboot flash recovery recovery.img same fastboot flash boot boot.img same On the phone: *After a successful flash, choose RECOVERY MODE *Select "apply update from ADB" In the command window: Type *ADB sideload UL-ASUS_Z00D-WW-12.16.5.118-user.zip *Press enter Wait for success! Summary: if Asus flash tool fails, use ADB sideload to flash the zip firmware. Links: https://www.asus.com/zentalk/in/thread-28147-1-1.html |
The Following User Says Thank You to Joel_Baah For This Useful Post: |
05-30-2020, 08:28 | #5 (permalink) | |
Insane Poster Join Date: May 2017
Member: 2712589 Status: Offline Thanks Meter: 6 | Quote:
C4ATAS000000 fastboot PS C:\adb> fastboot flash fastboot droidboot.img sending 'fastboot' (12181 KB)... OKAY [ 0.863s] writing 'fastboot'... OKAY [ 1.447s] finished. total time: 2.313s PS C:\adb> fastboot flash recovery recovery.img sending 'recovery' (9501 KB)... OKAY [ 0.765s] writing 'recovery'... OKAY [ 1.249s] finished. total time: 2.017s PS C:\adb> fastboot flash boot boot.img sending 'boot' (8793 KB)... OKAY [ 0.737s] writing 'boot'... OKAY [ 1.213s] finished. total time: 1.954s PS C:\adb> adb devices List of devices attached * daemon not running. starting it now on port 5037 * * daemon started successfully * 0123456789ABCDEF sideload PS C:\adb> adb sideload UL-ASUS_Z00D-WW-12.16.5.118-user.zip Total xfer: 2.00x after flash complete dont be forget to reset from recovery i got done pettern lock unlock done thanks for sharing your knowledge | |
11-23-2021, 09:06 | #6 (permalink) |
Member: 2203321 Status: Offline Thanks Meter: 46 | Simplest way. Use octopus frp to read info this will enable ADB. You can also use CM2 AST to read info to enable ADB. Now reset phone in ADB. JOBATECH unlocks - Ghana |
11-23-2021, 09:07 | #7 (permalink) |
