10-06-2020, 13:02 | #5 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | AUTH info: MTK, version: 1 BROM version[1]: 7.1922.6.0 DA: MTK_AllInOne_DA[1].bin hash: 29541b6af15c397977fb6c85df452c0add11ca18, size: 1.01 MiB version: 3.3001.2019/06/02020/10/06 09:00:08, start addr: 0x40000800 Connecting to BootROM... Power off the phone, disconnect and reconnect the battery(if possible) and connect USB cable... Hold the VOL DOWN or VOL UP + DOWN(for newer model) to force MediaTek BootROM. Scanning BootROM or Preloader port... Done Detected [BootROM] MediaTek USB Port_V1632 (COM3) Connection status: EHCI:HUB:HUB:USB 1.10 High-Speed USB Driver: [MediaTek Inc.] wdm_usb, version: 3.0.1504.0, date: 1-22-2015 Connecting Bootrom... Requesting flash signature from server... [SERVER] Sorry, We have run out of all available slots, please try again in 4 hours. Platform: MT6765, Hw ver: 0xCA00, Sw ver: 0x0000 BROM_SCMD_SLA error. code 0x7046 (boot_rom.cpp, line:1280) Bootloader authorization failed. ufi that promises to always make the server busy Any solution any procedure? |
10-06-2020, 15:31 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | Quote:
10-06-2020, 22:11 | #8 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Rio de Janeiro - Brasil
Member: 797068 Status: Offline Thanks Meter: 75 | same problem Requesting flash signature from server... [SERVER] Sorry, We have run out of all available slots, please try again in 8 hours. Platform: MT6765, Hw ver: 0xCA00, Sw ver: 0x0000 BROM_SCMD_SLA error. code 0x7046 (boot_rom.cpp, line:1280) Bootloader authorization failed. |
10-19-2020, 19:43 | #11 (permalink) |
Insane Poster Join Date: Mar 2014 Location: Sudan
Member: 2148927 Status: Offline Thanks Meter: 16 | Hi bro You will find the solution in this post https://halabtech .com/tag/flashing-error-mi-play/ تم الإرسال من vivo 1921 باستخدام Tapatalk Last edited by seanet2002; 10-19-2020 at 19:49. |
10-27-2020, 15:17 | #12 (permalink) | |
Member: 797068 Status: Offline Thanks Meter: 75 | you could post this solution here, because not everyone has access to halabtech! you could post this solution here, because not everyone has access to halabtech! Quote:
10-29-2020, 19:03 | #14 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Every 1's heart
Member: 682054 Status: Offline Sonork: 100.1602688 Thanks Meter: 144 | The worst ever phone of Xiaomi ....i have 3 pcs same issue cannot flash bcoz of faulty EMMC .....................Most of them EMMC issue need to change .....i tried isp direct connection flash by vendor but discoonects in the middle |
10-29-2020, 22:36 | #15 (permalink) | |
Member: 797068 Status: Offline Thanks Meter: 75 | put v3.3 if it fails just insist that you can do it, I made 1 today, using medusa pro Quote:
put v3.3 if it fails just insist that you can do it, I made 1 today, using medusa pro | |
