Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 11-22-2019, 03:13   #586 (permalink)
Member: 2910936
Originally Posted by ruvan View Post
I need help, I bricked my redmi 5 plus trying to find solution to get rid of MI account stuck on it. Now all the firmware i've found in the internet and used to revive it, it gives me stuck in the RECOVERY option screen except for this only one chinese version firmware. Now is there any way i can take it back to it's original state even put into global version?
Unlock the bootloader and then flash with the stock ROM
Sent from my POCO F1 using Tapatalk
Old 11-22-2019, 04:13   #587 (permalink)
Member: 241650
Thanks Meter: 71
I can't unlock it because it says " sorry your MI ID is not associated with phone numbers". Is there any way?
Old 11-22-2019, 04:20   #588 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 471
Originally Posted by cheyn View Post
Password for the zip file,please
Sorry, the file you have requested does not exist.
Old 11-22-2019, 04:44   #589 (permalink)
Member: 241650
Thanks Meter: 71
I can't unlock it because it says 'sorry your MI ID is not associated with phone numbers'. Is there any way?
Old 11-22-2019, 04:49   #590 (permalink)
Member: 241650
Thanks Meter: 71
I've flashed it already with stockroms thru EDL mode. I can't unlock the bootloader coz I don't own the MI account associated with it.
Old 11-23-2019, 12:36   #591 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Well, I ask you not to continue repeating publication after publication, in the end you will be sanctioned, be patient and wait for a user to answer a solution or you will simply have to find it yourself, as we all do.
Old 11-28-2019, 07:07   #592 (permalink)
Member: 473386
Thanks Meter: 31
what is password on archive?
Old 11-28-2019, 07:50   #593 (permalink)
Member: 473386
Thanks Meter: 31
Good, all the modified firmware you have in this link https://www.androidfilehost.com/?w=files&flid=296383, thank you very much.
What pass MI 8 depper archive?
Old 11-28-2019, 09:41   #594 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, do not repeat the same post, please bother and look for the passwords, ok, on page 28 or 29 the passwords are posted.
Password:
TODOSLOSARCHIVOSLLEVANCONTRASEŅA
Fran2110
unzip with 7zip, if you fail to copy and paste the passwords put them manually
The Following User Says Thank You to Franky_36 For This Useful Post:
Old 11-28-2019, 12:05   #595 (permalink)
Member: 473386
Thanks Meter: 31
Password:
Fran2110
Flash ok, but still locked, any solution?
Old 11-28-2019, 12:18   #596 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, flash the modified firmware, do not connect to Wi-Fi or data and then with debugging activated or adb, we do antirelock, it depends a lot on which version of miui or version of android the xiaomi is.
Old 11-28-2019, 18:53   #597 (permalink)
Member: 473386
Thanks Meter: 31
After flash phone is locked on mi (screen), no wifi conected.
Old 11-28-2019, 19:28   #598 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, try this file I leave the link: https://www.androidfilehost.com/?fid...86940962615254
Old 11-29-2019, 21:55   #599 (permalink)
Member: 473386
Thanks Meter: 31
Error when flashing system
Old 11-29-2019, 23:38   #600 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Any chance to have Mi9 SE bypass firmware?
Page generated in 0.23707 seconds with 9 queries
