02-01-2021, 21:27 | #1 (permalink) |
Insane Poster Join Date: Feb 2009 Location: Brasil
Member: 971926 Status: Offline Thanks Meter: 13 | Mi Play wipe data error Resultados de tradução Hello guys, I have several Mi Play and they all have the same problem, they are stuck in bootloop. When I try to write the firmware by SPFlash it goes to the end but in the "Userdata" simply pause and the time in the program continues running but does not end. I have already tried to write the engineer firmware and the result was all OK without selecting the "userdata" but even so the device will not turn on. I tried to write several different versions and even then the error in "userdata" remains. As the "Recovery" is different in the firmware engineer, I also tried to format there and after a few minutes the device restarts alone without finishing. All the firmware that I passed after they tried to read the data to confirm that it is not a write failure, and it is not. Every time the firmware is successfully written with the exception of "userdata" Do you have any more tips than trying? |
