09-08-2018, 20:33 | #1 (permalink) | ||
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | [FAQ][Anti-Rollback] All your questions are answered here. So, as we know with recent MIUI update Xiaomi screwed our whyred. And this gave birth to many questions which is like a struggle for many users to find all those answers. So, I tried to answer all your questions. If you think your question isn't included please feel free to ask. Q1: What is this "Anti-Rollback" thing? A: Its a security measure that Google brought with the release of Android Oreo. It makes sure that your data is secure even when phone is stolen or if any attacker tries to downgrade the software and wants to gain control over your data. Q2: How is this harmful to my device? A: Well, as a security measure it should never give you a hard-brick. When someone tries to downgrade, it should display a warning and get turned off but there's difference between how things should work and how Xiaomi does. As Google has stated, "Anti-Rollback" should get automatically turn off when the user unlocks the bootloader but in case of MIUI even unlocked users are getting hard-bricks. Hopefully the developers of MIUI should push an update soon and if they don't, our beloved devs will find a way for sure Q4: So, what now? Will Xiaomi solve this issue? A: We do not know. But our beloved developers in the XDA-Forum will find a way for sure Q5: How to know if my device is affected by it? A: Run fastboot command : Quote:
Q6: I'm in the Anti-Rollback squad what now? A: Don't worry you can still flash custom recovery and roam around custom ROMs but avoid flashing any firmware or any MIUI ROM which is older than what you're using now otherwise you'll brick your device. Q7: Which MIUI builds include "Anti-Rollback"? A: All the MIUI builds which are released after Stable MIUI V9.5.17.0 and Beta MIUI V8.7.5 include "Anti-Rollback". And yes the Chinese versions are affected as well. Q8: Do MIUI Stable V9.5.17.0 and Beta V8.7.5 have "Anti-Rollback" enabled? A: NO. If you're on either of these builds you are safe to downgrade and use any older version. Q9: How to flash custom recovery and custom ROMs on "Anti-Rollback" enabled devices? A: On "Anti-Rollback" enabled ROMs you cann't flash custom recovery permanently. You'll have to boot into recovery first by running fastboot command: Quote:
Q10: Can I migrate from Stable to Beta and vice-versa? A: You can install Beta from Stable, make sure you flash latest Beta build same is the case with Stable. If you're on anti-4 firmware, whether its Beta or Stable you can switch to any anti-4 MIUI ROM Beta or Stable but remember you must flash latest version available while switching. (anti-4 means "Anti-Rollback" enabled firmware) Q11: Can I unlock bootloader and flash custom ROMs on an "Anti-Rollback" enabled device? A: Yes. Again to flash custom ROMs and recovery refer to Q9. Q12Can I flash "Anti-Rollback" enabled ROM via TWRP? AWell, in some cases it did work, just flash lazy flasher zip file after flashing MIUI ROM via TWRP. But while switching to MIUI from AOSP based ROMs on an "Anti-Rollback " enabled device I recommend you to go with fastboot method to avoid chances of brick. Source is XDA | ||
The Following 9 Users Say Thank You to ~Leo~ For This Useful Post: |
09-08-2018, 22:17 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,105 | Anti-rollback its for system only its Can be baypassed by writing dummy.img file included in factory rom in fastboot And mi authirization its for firehose edl flash autorisation this auth is hard to baypass Last edited by rebainoor; 09-08-2018 at 22:26. |
The Following User Says Thank You to rebainoor For This Useful Post: |
09-08-2018, 22:58 | #3 (permalink) |
Member: 231728 Status: Offline Thanks Meter: 2,105 | Hi these phones have new authentication system (done by Xiaomi) i call it SIG, because them added new command to his Firehose programmer's. Things to need to know: 1. QC was always implemented SW_VERSION (RollBack) tag in his certificate validation schema, but nobody was used it before (Except Samsung and LG) 2. After FireHose is Validated, OEM manufacturer is free to add his own secondary authentication (First was introduced in old SE phones which was need SE validation card, now old golden idea was taken by Xiaomi and auth protocol moved to server) So what in fact we can do: 1. Need to Have FireHose Programmer signed to current eFuse Value with sme HW_ID and Higher or Same SW_ID (Included RollBack Version) tags without a SIG authentication extension. Here is importan RollBack Version, is activated then tag value is > 0 How we can recognize it: Unfortunatelly Sahara Protocol, not let us to read SW_ID tag and choose right RollBack Satisfied Firehose Automatically Fast boot "getvar:all" will show "RollBack Version" or "Anti" Variable who reflects RollBack (SW_VERSION) value How to check is FireHose Ready to do jobs: Jus Open it wih notepad and look for "SW_ID" Here You will see Hex Value string: 0000000200000003 SW_ID Here You see RollBack (SW Version) = 2 So with this FireHose can serve : RB: 0, 1, 2 and cannot work with 3, 4, ... How to see is FireHose Need Xiaomi Authentication or not is same open with note pad and search for this string: "sig " (white space is important here) if not found "sig " - you are lucky: this FireHose not need it. And for sure do not forget that Root CA HASH must be same as is in eFuse (QFPROM) |
The Following 8 Users Say Thank You to rebainoor For This Useful Post: |
06-07-2019, 21:47 | #5 (permalink) |
Junior Member Join Date: Dec 2018
Member: 2883324 Status: Offline Thanks Meter: 0 | hi everybody! after bypass micloud to my redmi 5 plus sensor like calling and fingerprint don't work +I really need solution about that Sent from my Redmi 5 Plus using Tapatalk |
08-03-2019, 16:24 | #6 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Gautam Buddha Nagar Age: 35
Member: 1291309 Status: Offline Sonork: [email protected] Thanks Meter: 58 | redmi note 5 pro dead after wrong modle flash i have try letest ver flash but not on phon only conect edl mood i have try more file but not on ands try anti roolback firme waer all ver flash ok whit mi tool but not on tell me any solution how to recover which file ok my phone..?? adwance in thanx |
08-06-2019, 08:17 | #7 (permalink) | |
Freak Poster Join Date: Mar 2017 Location: Tajikistan Age: 39
Member: 2695998 Status: Offline Thanks Meter: 68 | Quote:
You need to flash it with auth mi ID than phone take on | |
08-07-2019, 10:52 | #9 (permalink) | |
Member: 1291309 Status: Offline Sonork: [email protected] Thanks Meter: 58 | Quote:
i have to try many file nad formate and mi cloude whit umt note one my phone any tested solution tell me which file working my phone ....i have to try anti rollback note solve my probelm...........Help | |
