redmi note 4 2016100 how to reboot to edl mode redmi note 4 2016100 how to reboot to edl mode solution need?? this model (locked edl) its not mtk Mi Deep Flash USB Cable not work fastboot to edl cmd not work vol key not work anyone have tested solution ??? thanks .. |
use edl mode cable enjoy |
Regards |
i have same problem.........badly need this solution:confused::confused: |
EDL process Redmi Note4 Press vol up + dn power and press also cable button .. while handset off..release cable button.. quickly.. and press again |
is that redmi note 4 is mtk YES ITS SHOULD BE MTK EDL MODE ONLY FOR QUALCOMM CPU IN MTK YOU CAN DO ALL THE FUNCTIONS IN FASTBOOT MODE THAT YOU DO IN EDL MODE :) |
Does any body get success in this i am also stacked on this |
You can't flash note 4 with locked bootloader, even in edl mode, mobile enter in edl mode easily with mi flash Cable. Your another option for flash is qfil, download fastboot file and flash with qfil Sent from my Redmi Note 4 using Tapatalk |
vol+ and powe phone will in sildemode open umt qcfire in xiaomi/tool select mimax just do factory reset 100% done i do many modal sorry for endlish |
if its qualcomm boot in fastboot mode ( press vol down and insert usb till see fastboot mode) after that use any tool ( nck qualcom ) or cmd to put into edl mode 2- using edl cable ( keep presing vol keys ) reg |
If you want to enter EDl Xiaomi Note 4 x(Qualcomm) try to open back cover, and do TestPoint, then connect cable, phone in Edl, how to do test point you may seek in google Send from SkaZsKA |
