Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 08-08-2018, 17:16   #1 (permalink)
Member: 2279433
redmi note 4x 2016101 hang in logo problem
flash in EDL MODE NOT SOLVED PROBLEM
ANY HELP ????
Old 08-26-2018, 14:21   #2 (permalink)
Member: 550401
Thanks Meter: 19
any update for this?
Old 08-26-2018, 14:23   #3 (permalink)
Member: 550401
Thanks Meter: 19
did you try this?
Xiaomi MIUI Official Forum
Old 08-26-2018, 14:39   #4 (permalink)
merdjiosse's Avatar
Member: 479679
Thanks Meter: 53
hi same problem with same model here
i try two different version :
mido_global_images_V9.6.2.0.NCFMIFD_20180716.0000. 00_7.0_global_228dc638d1.tgz
mido_global_images_V9.0.5.0.NCFMIEI_20171113.0000. 00_7.0_global_b13588b4d7
but same
the problem was after mi accoiunt remove with U.A.T tool
so any solution?
Old 08-26-2018, 19:45   #5 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,120
ANY HELP ????
Hi, I leave the link to the official forum of xiaomi, if you get error the official software of xiaomi, try QFIL or another tool if you have umt etc, thanks.
Xiaomi 4x 2016101 rom - Redmi Note 4X - Xiaomi MIUI Official Forum
Old 08-26-2018, 19:51   #6 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,120
but same
so any solution?
Good, you turn the xiaomi in the cover down there is a numbering, according to that numbering you choose which is the correct firmware for your xiaomi, thanks.
And after removing the micloud account, what happens to the xiaomi, is bootlop, brick, connectivity problems?.
Old 08-26-2018, 20:06   #7 (permalink)
merdjiosse's Avatar
Member: 479679
Thanks Meter: 53
hi
bootlop only mi logo
Old 08-26-2018, 21:06   #8 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,120
hi
Good again, flashes with the correct firmware of your xiaomi and model and should pick up the phone, but first test if you can enter the recovery and do the wipes and you do not have to flash, you tell me how it went, thanks.
Old 08-28-2018, 14:49   #9 (permalink)
merdjiosse's Avatar
Member: 479679
Thanks Meter: 53
hi
i do wipe data from recovery but steel same
how to found the correct firmware for mi phone?
Old 08-28-2018, 15:34   #10 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,120
hi
Good, check the number on the back cover of the xiaomi, it will tell you the exact model of the xiaomi and there is to find the firmware, thanks.
I have told you the numbering because there are two types of models is xiaomi redmi note 4x and the xiaomi redmi 4x.
Old 08-28-2018, 17:06   #11 (permalink)
merdjiosse's Avatar
Member: 479679
Thanks Meter: 53
HI
this is what is wroten in the bnack of this phone
JY-L70516BV0-6
YH17-05-17-23A2
Old 08-28-2018, 18:27   #12 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,120
HI
JY-L70516BV0-6
YH17-05-17-23A2
hello again, there are only two models:
Xiaomi Redmi note 4X
Xiaomi Redmi 4x
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.15472 seconds with 7 queries
