Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 10-28-2021, 20:52   #1 (permalink)
Member: 2906470
Thanks Meter: 29
Cool Repair Poco X3 pro Dual Imei Hardware Solution
The Following 5 Users Say Thank You to ghayoum1 For This Useful Post:
Old 10-28-2021, 22:36   #2 (permalink)
Member: 2099940
Isn't there a way to do it without physically changing the resistance?
What are the previous steps you have done, after which steps did you find the need to do this? (I'm a bit new)
Old 10-29-2021, 10:22   #3 (permalink)
Member: 2906470
Thanks Meter: 29
No, it is not possible without changing the resistor, the first thing is to change the resistor, you can learn to continue working inside the Telegram channel.
T.me/digivita1
Old 11-22-2021, 07:28   #4 (permalink)
Member: 2628089
Sonork: 100.1670212
Thanks Meter: 102
Red face
Originally Posted by ghayoum1 View Post
Hello sir My Phone is All Ready Bootloader Unlocked when i change this restor then my phone is gona Bootloader locked and show (This Miui Varson Can't be installed on this device) And I Flashed Many File But Not Success Stock at recovery mode
The Following User Says Thank You to firmwarehouse For This Useful Post:
Old 11-22-2021, 09:29   #5 (permalink)
Member: 2986329
Sonork: Muhammad
Thanks Meter: 15
One guy posted it 2 or 3 days ago that its possible without hardware method.
He made this as a vid in youtube https://www.youtube.com/watch?v=v0MRwmJbpHM&t=365s.
I don't know its working or not without hardware method.I didn't test it.
I guess you re right here,it only works with hardware method.
The Following 2 Users Say Thank You to Timur_1988 For This Useful Post:
Old 11-22-2021, 15:09   #6 (permalink)
Member: 2628089
Sonork: 100.1670212
Thanks Meter: 102
it's mtk
i need qualcomm ufs solution
Old 11-22-2021, 21:48   #7 (permalink)
Member: 2906470
Thanks Meter: 29
I tested this solution and working fine.
try another regoin miui version. or eng rom.
And make sure resistor valu.
The Following User Says Thank You to ghayoum1 For This Useful Post:
Old 11-24-2021, 20:51   #8 (permalink)
Member: 2990018
Thanks Meter: 2
Repair After Factory Reset/ Flash Possible?
The Following User Says Thank You to FileLagbe For This Useful Post:
Old 11-28-2021, 17:22   #9 (permalink)
Member: 2906470
Thanks Meter: 29
if your mean is stable imei.yes,its stable still after flash and factory reset
Old 11-28-2021, 18:12   #10 (permalink)
Member: 2990018
Thanks Meter: 2
I want to know Resistance value? Or which motherboard available this resistance?
Old 12-02-2021, 20:52   #11 (permalink)
Member: 2906470
Thanks Meter: 29
more information in telegram channel
T.me/digivita1
Old 12-09-2021, 12:03   #12 (permalink)
Member: 2628089
Sonork: 100.1670212
Thanks Meter: 102
i fash eng rom then write imei2 then i put a sim card then my phone is bootloop
Old 12-15-2021, 20:09   #13 (permalink)
Member: 975562
Thanks Meter: 46
i have same problem bootloop after write imei2 with eng rom,
Old 12-15-2021, 20:27   #14 (permalink)
Member: 592636
Thanks Meter: 674
thats poco c3 with mtk cpu .
Old 12-21-2021, 17:00   #15 (permalink)
Member: 2993217
i need poco x3 schematic diagram help plzzz
Page generated in 0.32680 seconds with 8 queries
