10-12-2022, 21:29 | #4 (permalink) | |
Junior Member Join Date: Sep 2010
Member: 1399763 Status: Offline Thanks Meter: 1 | Quote:
If all you want is the MIUI 13 with Android 12 you don't need to unlock the bootloader. Or if your goal is to remove the Mi Account then you need to have access to the original email or phone number associated with that account. Sent from my Redmi Note 9 Pro using Tapatalk Last edited by cevi; 10-12-2022 at 21:42. | |
10-13-2022, 11:20 | #5 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | Quote:
how did you update ota ? via recovery ? there is no option to flash recovery ? | |
10-13-2022, 11:34 | #6 (permalink) | |
Using the volume buttons for navigation up or down go to the last option Mi Assistant. Then press power button once to enter the mode. Use Mi Flash Pro for flashing the recovery ROM. But first please confirm what MIUi version is your phone by going to Settings, About menu Is it EEA, Global or some other. Post it here so I can check for the availability. Sent from my Redmi Note 9 Pro using Tapatalk | |
The Following User Says Thank You to cevi For This Useful Post: |
10-14-2022, 06:45 | #7 (permalink) | |
miui_CURTANAGlobal_V13.0.2.0.SJWMIXM_65c5d3fcff_12 .0 but flashing fail and says success with red cross phone is mi locked so flashing supported via recovery ? Last edited by Mr.3.; 10-14-2022 at 06:53. | |
