Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 09-11-2018, 20:26   #1 (permalink)
Member: 980958
Thanks Meter: 16
Redmi 6a MI Account
Hello.
Need help, have a Redmi 6A MI Account.
Thanks
Old 09-11-2018, 21:52   #2 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Originally Posted by mps203 View Post
Hello.
Thanks
Good, how will you know this xiaomi model is mtk and has secure boot, I leave the modified firmware, I do not know if you will use sp flash tool or miflash or have professional tools, such as umt, bst, mrt, etc, any doubt or problem comments, Thank you.
http://www.mediafire.com/file/ga8duy...S%2529.7z/file
Old 09-12-2018, 14:46   #3 (permalink)
Member: 980958
Thanks Meter: 16
with sp flash tool, mark error (fastboot connection mode)
I have Infinity CM2, NCK
Old 09-12-2018, 14:56   #4 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, with these tools is also worth of course, keep in mind that you will be asked for the secure boot, as I'm sure you'll know, thanks.
Old 09-12-2018, 16:22   #5 (permalink)
Member: 980958
Thanks Meter: 16
I can not load firmware file. All tools mark file error
Old 09-12-2018, 16:23   #6 (permalink)
Member: 980958
Thanks Meter: 16
Sp flash tool scatter bad
infinity cm2 scatter or .bin BAD FILE mark
Old 09-12-2018, 16:39   #7 (permalink)
Member: 1188874
Sonork: 100.1610116
Thanks Meter: 8
https://www.gem-flash.com/vb/threads...5%D9%86-MIUI-9
try this it worked with note4
Old 09-12-2018, 20:04   #8 (permalink)
Member: 980958
Thanks Meter: 16
Originally Posted by siso4 View Post
not work option share
Old 09-16-2018, 08:19   #9 (permalink)
Member: 2864922
Thanks Meter: 45
try this web link jpcomms,there is a lot of remove mi account files and include redmi 6a remove files bro
Old 09-16-2018, 10:05   #10 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, here you have the modified firmware of the xiaomi redmi 6A, any questions or problems comment, thank you.
REDMI 6A &_40;CACTUS&_41;.7z - 1795766892
The Following 3 Users Say Thank You to Franky_36 For This Useful Post:
Old 09-30-2018, 12:40   #11 (permalink)
Member: 488739
Thanks Meter: 7
File Not Found/////////////
Old 09-30-2018, 13:44   #12 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, if this server respects the links and does not delete them, a thousand apologies, here is the link, thank you very much.
https://mshare.io/file/qEiJdP
The Following User Says Thank You to Franky_36 For This Useful Post:
Old 09-30-2018, 13:46   #13 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Here is the link, thank you very much.
The Following 4 Users Say Thank You to Franky_36 For This Useful Post:
Old 10-03-2018, 14:27   #14 (permalink)
Member: 2147680
Thanks Meter: 32
thanks Franky_36, but i have a question, how to flash redmi 6a with locked bootloader?
i can not flash with spflashtool event stock rom!!!
The Following 2 Users Say Thank You to nguyenthaiau For This Useful Post:
Old 10-04-2018, 18:06   #15 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Good, you can flash both with sp flash tool, loads the scatter.txt, phone off, press vol + and connect the mobile with the usb cable, in case you get an error by da agent, in the sp flash tool folder , there are several da agent, try it, to remove the account micloud format + download, thanks.
Page generated in 0.24507 seconds with 8 queries
