Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 09-21-2012, 06:54   #3061 (permalink)
Member: 1665289
Thanks Meter: 59
Originally Posted by Haloss View Post
Please upload the Rom from one x !
Hi,
Here is some rom`s for you.
One X Original Android Development - xda-developers
good luck.
Old 09-26-2012, 09:23   #3062 (permalink)
Member: 1803155
thank you, i will regard it as a good idea
___________________________________________
like shopping when i have a good time
Guild Wars 2 Gold|GW 2 Gem|Diablo 3 Gold|Cheap RS Gold
Old 09-26-2012, 12:29   #3063 (permalink)
Member: 1711037
Thanks Meter: 8
hd mini t5555
1.36.408.1 rom
radio 0.63.5.36 plz
Old 09-28-2012, 16:29   #3064 (permalink)
Member: 1804174
i need arabic room for my device htc desire v
Old 09-28-2012, 16:29   #3065 (permalink)
Member: 1804174
pleeez help me ......................................
Old 10-22-2012, 19:32   #3066 (permalink)
Member: 267789
Thanks Meter: 5
desire v
i need french rom i have 2pcs
Old 11-06-2012, 07:15   #3067 (permalink)
Member: 1707581
Sonork: mahdierika
i have htc mini photon it have dutch language i want to change English ROM version 1.09.404.1. radio version 0.63.05.36 any body help me pls
Old 11-06-2012, 07:15   #3068 (permalink)
Member: 1707581
Sonork: mahdierika
Old 11-07-2012, 05:59   #3069 (permalink)
Member: 1665289
Thanks Meter: 59
1.dowload rom Shipped ROMs
2. Flash phone.
3.Enjoy new rom
Old 11-10-2012, 11:45   #3070 (permalink)
Member: 1714970
How To Upgrade Your HTC Universal ROMs [Work In Progress]
New TopicPost ReplySubscribePermalinkRSS Feed
rhmartin • Member • 1114 postsQuote • 28.10.2007 03:07 • 1 people like this •
Disclaimer:
* compiled from resources in the web, no claims of ownership made for texts & figures adopted in the post
* ROM update involves erasing & replacement of OS & Radio ROM's. Although the instructions had been carefully & meticulously written based from experience, there's a possibility of incidents beyond your control that may brick your device.
* It is preferable to use a fully charged notebook or a UPS powered PC to avoid power loss which could brick your device during the update.
What you need before the upgrade:
The following procedures are required if you intend to rollback to the Original WM5 ROM (in case you want to sell the device), otherwise if you have the installation files or a download of your original WM5 ROM, then skip procedure below & proceed to 1.k.
1. Backup your Bootloader, Extended ROM, WinCE ROM, Radio ROM & PIM (contacts, tasks, emails)
Using MTTY116 Utility uploaded here:
a. Disable USB ActiveSync connection in your PC/Notebook
b. Place PPC in bootloader mode: Press & hold Power + Backlight + Reset until text "Serial appears in PPC screen
c. Connect your PPC to PC/Notebook using the USB cable
d. Run MTTY.exe in your PC
e. Select \\. \WCEUSBSH001in the Port drop down list
f. Insert a blank 128Mb SD/MMC card in PPC
g. Click "Ok" & Press "Enter" in the MTTY screen to display USB> prompt
h: Type task 32
USB>task 32
USB>d2s 70000000 80000 (this will backup your bootloader to SD/MMC)
Press Enter
“Store image to SD/MMC card successful” displays in PC & "Checksum Ok" should display in PPC if successful
USB>d2s 70100000 3FA0000 sd a (this will backup your WINCE ROM & Splash screen to SD/MMC)
Press Enter
Wait for 7 - 8 minutes
USB>d2s 74100000 A00000 sd a (this will backup your Extended ROM to SD/MMC)
Press Enter
USB>d2s 60000000 a24200 sd a (this will backup your Extended ROM to SD/MMC)
Press Enter
i. Backup of Bootloader, Extended ROM, WINCE + Splash Screen & Radio ROM is done. Remove SD/MMC
j. Soft Reset
k. To backup PIM:
Use ActiveSync to synchronize PPC with MS Outlook. The backup created by the built-in PPC programs/utilities may not be readable in the new OS to be installed.
2. You need to choose an OS ROM (usually nk.nbf, or an automated install exe file)
You need to decide which Windows Mobile (WM) version plan to install
If you want a fully functional OS choose WM5
If you want the latest technologies & enhancements but no video call (as of today Oct 27 2007) choose WM6
3. You also need to choose a Radio ROM (radio_.nbf)
Some upgrade files comes with both the OS & Radio ROM
The currently recommended version is V1.15. Version 1.18 is available & some are using it without any problems
You may choose to retain your current radio ROM even if it's not the recommended one, just remove the radio_.nbf file in the upgrade directory.
4. Your HTC Universal USB data/charger cable
5. Microsoft ActiveSync (AS) installed in your PC or Notebook. AS version 4.5 is required if you choose WM6 ROM
Preparations in your PC/Notebook:
1. USB cable is directly connected to the PC (don’t use USB hub).
2. Disable the standby and hibernation modes on your PC (these may interfere upgrade process)
3. You need to close all other applications on your PC.
4. Extract the upgrade files if it is in .rar or .zip archive into a directory in your PC. Example: C:\Temp
5. Check for the file contents in the C:\Temp (as in example above) the ROM package should contain:
a. EnterBL.exe
b. GetDeviceData.exe
c. MaUpgradeUt_noID.exe (this is a special file created to bypass country, language ID checking of your device)
d. RUU.conf
e. RUU.dll
f. UI.dll
g. nk.nbf (this is your OS ROM)
h. radio_.nbf (this is your radio ROM)
If you only have the OS & Radio ROM's (nk.nbf & radio_.nbf), just extract the ROM Package above & drop the OS & Radio ROMs in the directory.
Preparations in your HTC Universal
1. Ensure that your device is fully charged. Failure to do so may brick your device!
2. It is highly recommended to remove the SD Card in your PPC slot.
The Upgrade Procedure
1. Put your device into “Bootloader mode” :
Press & hold backlight and power buttons then press reset button (the text "Serial" should appear at the top of the screen)
2. Connect your device to the PC/Notebook using the USB cable. (The text "USB" should replace the text "Serial" at the top of the screen)
3. Go to your PC & execute (double click) MaUpgradeUt_noID.exe
The Welcome screen should display in your PC:
Read more: How to upgrade your HTC Universal ROMs [Work in progress] :: Forum
Follow us: @buzzdev on Twitter
Old 11-11-2012, 01:30   #3071 (permalink)
Member: 1107584
Dear SUBRATA,
niki 100 stuck in boot logo, no hard spl, no os. cid locked - Tim
it's possible for you find the shipped tim rom?
italian or portuguese.
I try the dumped version, but don' work.
Sorry for the bad english.
Thanks.
Old 11-11-2012, 10:08   #3072 (permalink)
Temporary banned !!
Member: 1003683
Thanks Meter: 8
Please HELP need htc raph100 ENGLISH rom and spl....THANKS IN ADVANCE
Old 11-11-2012, 17:14   #3073 (permalink)
Member: 1665289
Thanks Meter: 59
hi,
Originally Posted by AngeliNero View Post
Dear SUBRATA,
Thanks.
try one from this link : Shipped ROMs
Old 11-11-2012, 17:28   #3074 (permalink)
Member: 1665289
Thanks Meter: 59
Hi ..
What model phone do you have?
a) CDMA: Alltel HTC Touch Pro / Bell HTC Touch Pro / Sprint HTC Touch Pro / Telus HTC Touch Pro / Verizon XV6850 / au E30HT ..?
b)GSM: HTC T727X / HTC Touch Pro / Orange HTC Touch Pro / Swisscom HTC Touch Pro / Vodafone HTC Touch Pro / AT&T HTC Fuze / O2 Xda Diamond Pro / O2 Xda Serra / T-Mobile MDA Vario IV / SoftBank X05HT / NTT DoCoMo PRO series HT-01A.... ?
1. Read about htc raphael :HTC Raphael - XDA-Developers
2. Find appropriate rom for your phone here
Shipped ROMs
or here : Shipped ROMs
good luck.
Old 11-11-2012, 21:42   #3075 (permalink)
Member: 1107584
Noop... don't work... I need TIM signed rom... Cid locked...
So... any sugestion?
Upload / Download eeprom program for 51xx/61xx Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-07-1999 14:03
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-24-1999 05:45
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.21584 seconds with 9 queries
