Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
![]() | #77 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2003 Age: 46
Member: 36825 Status: Offline Thanks Meter: 11 | Quote:
Xda 11i unlocker not working showing error,please share that file pleaseeeeeeeeeeeeee | |
The Following User Says Thank You to yasirmcp For This Useful Post: |
![]() | #78 (permalink) | |
Administrator ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002 Location: E G Y P T Age: 37
Member: 14178 Status: Offline Thanks Meter: 8,637 | Quote:
one last thing it doesn't support XDA II | |
The Following 2 Users Say Thank You to ..::Neo::.. For This Useful Post: |
![]() | #79 (permalink) | |
hi when i am trying to install soft i am getting this error message,(xda2unlock-setup-v2.2) before i try to unlock with xda2 unlock dos based software ,when program running time phone disconected,after phone only on with usb cable conected with computer,when disconecting showing message battery low and phone will off, before i am trying to unlock phone is good condition only network lock please help for solve this problem yasirmcp | |
![]() | #81 (permalink) |
Member: 36825 Status: Offline Thanks Meter: 11 | THANKS FOR U R GOOD MIND AND HELPING MENTALITY I WILL EXPLAIN THE PROBLEM,PHONE Xda 2i(for unlock) FIRST I TRY WITH XDA UNLOCK TOOL V1.2 THAT PROGRAM IS A DOS TYPE PROGRAM RUNNING .......,BUT PROGRESS TIME I WAIT 1 HOUR BUT PROGRAM NOT FINISHED,SO I DISCONECTED(BUT PROGRAM IS ON RUNNING MODE) AFTER FINISHING PHONE IS NOT ON WITHOUT USB CABLE CONECTING TO PHONE SECONDD I UPLODED SECOND SOFT xda2unlock-setup-v2.2 AND INSTALL TO PHONE,BUT IT RUN ON PHONE IT IS NOT GETTING THE CODE IT IS FAILED TO FIND THE CODE now phone is locked and it is not power on without conecting chrger please give any flashing soft to power on the phone after i will try to unlock pleaseeeeeeeeeeeee thanking you |
![]() | #82 (permalink) |
Member: 14178 Status: Offline Thanks Meter: 8,637 | @yasirmcp try to download ROM for your phone from here and upgrade your phone http://www.my-xda.com/xda2i_soft2.html B.R |
![]() | #83 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Aug 2004
Member: 78834 Status: Offline Thanks Meter: 0 | ![]() Quote:
Regards, -sdt1 | |
![]() | #84 (permalink) | |
HI ![]() THANK U VERY MUCH FOR U R HELP,I SOLVED THE PROBLEM THREW U R SUPPORT,I DOWNLOAD THE ROM FROM U GIVE THE LINK,WHEN I UPLOADED MY PHONE GET GOOD CONDETION BEFORE I TRY TO UNLOCK,PHONE ON WITHOUT THE SUPPORT OF USB CABLE, AFTER UNLOCKING WORKS 100%,NOW MY PHONE UNLOCKED IT IS A GOOD MAGIC NEO THANKS A LOT OF FOR U R GOOD SUPPORT AND GOOD SOFTWARE I AM PROUD OF U ,AND THANKING TO FORUM TO GET A GOOD MODERATOR FOR OUR SUPPORT THANKING YOU YASIRMCP ![]() | |
![]() | #85 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001
Member: 4270 Status: Offline Thanks Meter: 13 | Hi can some1 please help me with setting up Pocket PC 2003 internet and MMS on my handset. The problem im having is that how can u have internet GPRS and the MMS GPRS working. the thing is the mms is not working but the internet is fine . how can i set it up such that it will still have the internet and also be able to send MMS. Please help. the networks cant help me reo |
![]() | #86 (permalink) | |
Member: 78834 Status: Offline Thanks Meter: 0 | Quote:
Which service provider are you using? Typically, to set up MMS, you have to create two separate GPRS network connections, one with the APN of the MMS pass-through, and one for the APN of the Internet pass-through. Sometimes you must also create a proxy connection for both GPRS connections. Your service provider should be able to provide these settings for you. You can also check http://www.howardforums.com for more information about MMS/GPRS settings for most North American service providers. Regards, -sdt1 | |
:: All Motorola phones IMEI unlock :: | UnlockByLogs | All UnlockByLogs Server | 71 | 03-16-2009 09:04 |
::.:: All BlackBerry Keyboard Shortcuts only HeRe ::.:: | ::.::RAMJAN::.:: | BlackBerry (RIM) | 6 | 08-27-2008 11:48 |
::.:: All Blackberry Disassembly photos and instructions ::.:: | ::.::RAMJAN::.:: | BlackBerry (RIM) | 2 | 07-25-2008 19:44 |
..:: {All Sumsung Full Flash Download here free} ::.. | GamalyGsM | Samsung Flashers, Software, Firmware. | 11 | 04-19-2006 05:22 |
..::..ServiceSoft V2 ..::.. All this only for 50 EUR ..:: Let Us make your Job easy | mali_kruno | Main Sales Section | 0 | 11-03-2005 00:53 |
