HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
10-15-2008, 19:46 | #2 (permalink) | |
Freak Poster Join Date: Mar 2005
Member: 126801 Status: Offline Thanks Meter: 23 | Quote:
first i want to ask you is there any red light coming after you inserted the charger? if not try resolder the mini usb connector, worst case its mother board problem.... but its no problem if you will try also first to reformat it. some other cases if there some problem in the software there giving you a wrong data. | |
10-15-2008, 21:44 | #3 (permalink) |
Insane Poster Join Date: Apr 2006
Member: 255907 Status: Offline Thanks Meter: 12 | The red bulb does not burn, matter is not in a socket, I have removed it there on a payment short circuit, socket plus is called on weight. The diode any can the controller is worse (((. There is no scheme of a similar body? The scheme charger not should strongly will cause a stir! Last edited by segacool; 10-15-2008 at 21:54. |
i have c160 there is not charging heat up charging ic | shani72 | Samsung Hardware Repair | 1 | 06-23-2009 07:01 |
Motorola W220 Charging Problem. Set Is Not Charging. | shahi | Motorola Hardware Repair | 0 | 11-12-2007 06:44 |
It Helps Unlock Motorola A835 Though It Is Not Free | WEBWOMAN€ | Phone Unlocking Codes & Maps | 11 | 04-23-2004 08:59 |
Hello anybody, my Nokia-3210 is not charging it is showing not charging | varma raj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-25-2003 11:27 |
