HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
09-13-2006, 17:57 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | HELP NEEDED !!! SD Backup image for qtek 9100 / HTC wizard .. where? I need urgently SD Backup for qtek9100 / htc wizard. Similar to this: http://en.pdamobiz.com/en/forum/PDAf...p?TID=151&PN=1 Please anyone that has this, appreciate your help |
09-14-2006, 00:24 | #4 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Damn... I walked around and around and solution was all near me and able to do it myself... Ok hereīs how I done it. First, I must explain what was the problem. After update the firmware (not actually upgrade, I had the phone full of trash, so I decided to reflash same firmware v2.18 PTG), the Qtek 9100 / HTC Wizard freezed at 2nd splash screen (the one that shows OS versions IPL version, ect). Tried many different versions, upgraded to 2.24, 2.25, downgraded even to 1.6.7.3, but always same problem, freezed on second splash screen. I read many topics on xda-dev, and seen some people with same problem. Apparently there was 2 solutions. 1- send phone back to warranty. 2- write backup ROM from SD in bootloader. Passed more then 15 hours asking for this SD backup everywhere, and COULDNīT find any help. Apparently no one had this "SD dump ROM Backup". So hereīs how I solved my problem 1- I tought that a SD backup was needed, and yes it is. But u can use your own phone and your own SD to do it. 2- Get a clean SD card (in qtek 9100 / Htc Wizard case is MiniSD) with 128MB (some people say 64MB, but I personally used a 128MB, maybe a 64MB is enough) 3- Kill (task manager) wescomm.exe (this is related with activesync installed on your PC). Insert the blank SD card on the phone. 4- Get your phone in bootloader mode. Like this : Phone powered off, press Camera button + Power On, will enter in bootloader mode (RGB screen). 5- Now connect your USB cable to your phone. And start MTTY_updateROM.exe (attached file). After open, on Port selection, choose \\.\WCEUSBSH001 and press OK. A window will open with a blank sheet. 6- Type "r2sd all" and hit enter... wait to the end (at end shows "cmd>"). On your phone screen u can follow backup progress... small bar will appear down the RGB screen. 7- Power off the phone (or remove battery), enter bootloader mode (camera button + power on) and this time RGB wonīt appear right away. Will ask if u want to "download SD image", press voice dial button to agree, and writting will begin. Wait to the end. Power off and power on normally. Now your phone should be working ok. Not even needed to reflash the phone after this. Thanks to all and hope this helps more people with this problem |
12-21-2006, 03:30 | #5 (permalink) |
Junior Member Join Date: Dec 2004 Age: 57
Member: 100093 Status: Offline Thanks Meter: 0 | one problem I read through your thread and another one at XDA-developers. I used this method to back-up the ROM of my Orange SPV M1500. Then I flash the phone with O2 upgraded ROM. It works although there are some tricks. However, after that, I want to flash the original Orange ROM back. But I failed everytime. The new O2 ROM seems stay there forever. I don't know how I can redo it. I have searched for the Orange ROM but no happy. Maybe some experts can do it? Please leave your message. Thanks! |
03-25-2007, 17:00 | #7 (permalink) |
Junior Member Join Date: Mar 2007
Member: 475509 Status: Offline Thanks Meter: 0 | Helllooo when i`m trying to do the back up i receive the following error: " r2sd all ***** user area size = 0x3CA0000 Bytes R2SDBackup() - Download type = 5 usTotalBlock = 1 sizeof(SDCARD_SIGNATRUE_TABLE)=512 You didn't get the proper security level to download a specific image Cmd>" Can u help me with this ? Thanks |
03-25-2007, 17:12 | #8 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 45
Member: 55631 Status: Offline Thanks Meter: 55 | Quote:
First of all you need to CID unlock your device (check this thread) then perform your desired operation... | |
12-24-2008, 08:32 | #10 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Saudi Arabia
Member: 476075 Status: Offline Sonork: na Thanks Meter: 40 | hi all my qtek wiza200 complete dead even not going to boot mode. i flashed kjam firmware and phone is dead. any body help me to enter in boot mode. |
09-09-2009, 01:43 | #11 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1115280 Status: Offline Sonork: accepted Thanks Meter: 0 | I need urgently SD Backup for qtek9100. If case found this file please send me via e-mail on : [email protected] or via skype on : gateway_in_prison Thanks and Best Regards to all |
09-10-2009, 23:19 | #12 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | Sorry to say... but itīs impossible to transfer the file out of SD. If was that easy, file would be available for download everywhere, and everyone saved their phones. In most, you can make the SD backup on other phone (if you find one, or a friend has one), and apply it into yours. |
09-11-2009, 08:39 | #13 (permalink) |
Member: 1115280 Status: Offline Sonork: accepted Thanks Meter: 0 | Thanks for answer. My next question is it - I change ROM on my device and after push ON button to start my PPC - freez in start screen. Insert SIM and LED indicate device work. I try call and Qtek ringing, but screen is freez. Please tell where I error in upgrade. Sorry for my bad english. Thanks and Best Regards |
11-04-2009, 02:58 | #15 (permalink) | |
Junior Member Join Date: Jan 2005 Age: 47
Member: 110121 Status: Offline Thanks Meter: 0 | which rom did you use i want to flash my m1500 with an o2 software Quote:
i find jtag solutions for Qtek 9100 and wizard | samirphone | HTC & PDA WM( With Touchscreen) | 0 | 10-26-2008 15:24 |
help me for Qtek 9100 | samirphone | HTC & PDA WM( With Touchscreen) | 0 | 10-13-2008 13:01 |
I need unlock for Qtek 9100 of digitel | johansel | HTC & PDA WM( With Touchscreen) | 0 | 11-19-2007 16:42 |
Newest English & dutch rom needed for qtek 9100 | to_deal_with | HTC & PDA WM( With Touchscreen) | 4 | 05-07-2006 14:42 |
Need flash for QTEK 9100, need better support for this solution | gsmnice | JAFWM | 0 | 05-04-2006 17:26 |
