HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
02-26-2009, 13:31 | #1 (permalink) |
Major Poster Join Date: Feb 2009
Member: 969815 Status: Offline Thanks Meter: 0 | problem with htc exca100 hello friends ... I have a problem with a htc exca100 when you turn keeps hanging on the home screen ... you did the master reset but still nothing remains the same ... |
02-28-2009, 00:42 | #3 (permalink) |
Member: 969815 Status: Offline Thanks Meter: 0 | I try to do that but I get an error when I am restoring the room and as I downloaded all 12 rooms and tells me error at 3% loading which leads ... if you can help me ...? thanks |
02-28-2009, 00:50 | #4 (permalink) |
Member: 969815 Status: Offline Thanks Meter: 0 | single room with a t-mobile comes to 7% with all other 3% is canceled the phone is Digitel Venezuela .... The error says "ERROR [270]: UPDATE ERROR The image file is corrupted. Please check your update utility" |
02-28-2009, 12:43 | #5 (permalink) |
Registered User Join Date: Apr 2006 Location: near to hyderabad ap india
Member: 259742 Status: Offline Thanks Meter: 215 | Error 270 fix For flash your rom, the best tool is Excalibur USPL- CID BYPASS thanks to Jockyw2001. Unlock first your telephone with SDA_ApplicationUnlock. When you have run the Excalibur USPL- CID BYPASS (run uspl), it turn white. When you have the error after flashing your rom disconnect the phone from your PC while the screen is white and reconnect it again. Then run the ROMUpdateUtility again. This will work. http://rapidshare.com/files/20355961...YPASS.zip.html http://rapidshare.com/files/20355995...nlock.zip.html |
The Following User Says Thank You to prasad3223 For This Useful Post: |
02-28-2009, 22:16 | #7 (permalink) |
Member: 969815 Status: Offline Thanks Meter: 0 | friend does not recognize the phone SDA_ApplicationUnlock ... you know it does not turn completely hangs on the screen that says HTC ... rioja lights flash mode and still does not recognize ... not to do ... I installed activesync |
03-01-2009, 16:37 | #8 (permalink) |
Member: 259742 Status: Offline Thanks Meter: 215 | -------------------------------------------------------------------------------- Hold the sym button down next to the right of the spacebar and then once holding it down for about 5 seconds plug the usb to the computer while still holding down that button. This should get you into bootloader mode. |
The Following 5 Users Say Thank You to prasad3223 For This Useful Post: |
03-01-2009, 16:42 | #9 (permalink) |
Member: 259742 Status: Offline Thanks Meter: 215 | Official ROMs - Download Links flash with ur original shippedrom to make ur device live HTC Excalibur 1.33.422.1 (Worldwide English, WM6)http://rapidshare.com/files/78865608..._Ship.exe.html 1.30.514.2 (Portuguese, WM6)http://www.mediafire.com/?9gbwdzd2omg 1.27.405.1 (Worldwide English, WM6)http://rapidshare.com/files/10023563...1.27.405.1.exe ??.?.?.? (BT rebrand, WM6)HTC_S620_WWE_BT_3.66.424.1_4.1.13.44_02.94.90_Ship .exe 1.15.0000 (Movistar Mexico, WM?)Dopod C720W 1.15.707.2 (Worldwide English, WM5)O2 XDA Cosmohttp://www.dopodasia.com/download/RU...63.90_Ship.exe Orange SPV E600 Rogers HTC 621 1.30.631.2 (WM6)T-Mobile Dashhttp://www.mediafire.com/download.php?5xuh3jv2yg4 1.22.531.6 (T-Mobile USA, WM6)http://www.mediafire.com/download.php?z4vjgzxisrz 1.22.531.4 (T-Mobile USA, WM6)http://www.mediafire.com/download.php?yygkw1d5xmc 1.11.531.1 (T-Mobile USA, WM5)http://rapidshare.com/files/10464194...531.1.exe.html |
06-12-2009, 14:00 | #10 (permalink) |
Junior Member Join Date: Jun 2009 Location: philippines
Member: 1045746 Status: Offline Thanks Meter: 0 | i have the same problem.. i have received message no system device found then my phone did not go to the home page and i turn it off it does not work.. what do you think my solution for this problem..please reply to my account or in this post..thankyou so much i am expecting for the reply. |
06-12-2009, 20:07 | #12 (permalink) |
Member: 259742 Status: Offline Thanks Meter: 215 | first download ur rom from above ...., then Flash from SD using original TMO rom -------------------------------------------------------------------------------- 1. OPEN RUU_Excalibur.exe with an archiver and extract files to temporary directory (the file we want is the EXCAIMG*.nbh) 2. Format SD card using FAT32 3. Insert SD card into phone 4. Connect using ActiveSync 5. Rename nbh file to "EXCAIMG.nbh" 6. Copy EXCAIMG.nbh to SD card 7. Disconnect phone 8. Start Manual Bootloader (hold camera key for three seconds and press power button) 9. After quick messages (checking sd card, etc.) you should get "Update SD image? Press power button to download" screen with countdown in bottom corner 10. After timeout you will go to color bars UI Exit bootloader: hold camera key, wait three seconds and hold down power key also until phone turns off My phone is not unlocked, so I didn't test with other roms. |
02-02-2010, 04:22 | #13 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | help me to get them Quote:
Strange Problem with HTC Trinity | imran_qasim | HTC & PDA WM( With Touchscreen) | 7 | 03-10-2010 12:57 |
unlocking problem with HTC[ANSWERED] | pachicoo | PolarBox 3 | 1 | 01-15-2010 20:19 |
Problem with HTC Touch HD | deYo | HTC & Smartphones ( WM Without Touch) | 0 | 11-12-2009 22:10 |
Problem with HTC Touch | harizhent | Various | 0 | 01-25-2009 21:45 |
i have problem with HTC | mbarek_oussema | HTC & PDA WM( With Touchscreen) | 3 | 05-15-2008 14:10 |
