Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 02-18-2010, 20:37   #1 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
How to make a GOLDCARD
Hi everyone!
Finally,I made this guide to show you how to create Goldcard.It’s not my creation,I just collected the informations.I tried to link the original source everywhere.
All credit goes to the original authors,programmers,etc….
What is a Goldcard?
A Gold Card is a memory card that has been converted to unlock your device's CID while it is in bootloader mode.
Goldcard is limited,you can use it 2 times,after that you have to generate a new one.
Info: http://wiki.xda-developers.com/index...e=Elf_GoldCard
Why do you need it?
If you have a semi-bricked device (doesn’t boot up,but you have bootloader) and you can’t find the matching CID ROM.
Sometimes it helps when you can’t flash your device properly,it stuck in bootloader after flash or just sometimes gives error during the upgrade.It’s my experience,it worked for me many times,but no one else confirmed that.
Anything you do,you do it at your own risk,I take no responsibility for any damaged,bricked device!
What we need for Goldcard:
-micro SD card (64MB-512MB)
-card reader
-QMAT software (my example is with version 5.06 TRIAL,NOTE:Trial version works for 10 minutes only!It's enough,Goldcard generating takes seconds.You can generate Goldcard for older devices only,for newer devices you have to buy the software.See the bottom of the page.)
-a working Windows Mobile device
Format your memory card for FAT32
If you have a card reader, go to DOS and type:
format <volume> /FS:FAT32 /A:4096
where <volume> specifies the drive letter of the SD card. For example: format d: /FS:FAT32 /A:4096
  • Instead, if you have another Windows Mobile device, you can use Resco Explorer to format it to FAT32.
Run QMAT to create the Gold Card
My example is a Charmer Goldcard
Put the newly-formatted SD card in the working WM device and connect to
Activesync
Run QMAT, go to the Hardware Forensics menu, and then select "Generate HTC Goldcard"
Select your bricked device's key
Get the SD Card Serial from WINCE Device (or enter it manually if you already have the Card ID)
Save the Gold Card image to the SD Card
Unbrick your device
Go to bootloader mode on your device with inserted Gold Card.
Disable USB connections in Activesync settings menu.Connect your device to your PC.
From your PC, run the RomUpdateUtility.exe from the RUU folder containing the shipped ROM
Alternatively, you can rename the shipped ROM (NBH file) to "XXXXIMG.nbh" (where XXXX is related to the model,for example:ARTEIMG,KAISIMG,etc...)and copy to your SD card, and then reboot your device to bootloader.
It should start flashing if everything is configured properly!
If everything went fine,the only thing you have to do is:enjoy your unbricked,running device!
About QMAT:It's NOT an advertissement,I'm NOT related to that company!
If you like and need this software (to generate Goldcard to newer devices) then buy it!
http://psas.revskills.de/
Download Qmat
PHP Code:
http://www.fishermangsm.com/Share4HTC/index.php?dir=Qmat/
or
PHP Code:
http://www.4shared.com/file/213507792/f0c8f77f/qmat506_official.html
The Following 30 Users Say Thank You to szig For This Useful Post:
Old 02-20-2010, 05:42   #2 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
Thread added to Sticky
Post only Gold Card related question in this thread.
All other posts will be deleted.
The Following User Says Thank You to .:SUBRATA:. For This Useful Post:
Old 03-18-2010, 07:35   #3 (permalink)
CDMA_RASHID's Avatar
Member: 821646
Thanks Meter: 507
How to get the serial number of the sd card.
Old 03-18-2010, 07:55   #4 (permalink)
Member: 30124
Sonork: 100.1590000
Thanks Meter: 7,900
Thanks Subrata, this is was much needed method for so many users since so long.
Great work dear, keep it up.
Old 03-18-2010, 08:11   #5 (permalink)
Member: 532812
Thanks Meter: 80
how to do this? Where to find it?
Old 03-18-2010, 08:34   #6 (permalink)
Member: 319447
Thanks Meter: 4,949
To do that, you have to press 1st button of Gold Card window.
The Following 2 Users Say Thank You to .:SUBRATA:. For This Useful Post:
Old 04-12-2010, 07:17   #7 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
If i want to save to pc, then which name i have to give to file and extention...............
Old 04-12-2010, 08:30   #8 (permalink)
Member: 319447
Thanks Meter: 4,949
you do not need to enter any extension manually.
Just save it
But i prefer direct making of gold card
Old 04-12-2010, 08:46   #9 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
It will give a name and extension for it,".bin" if I'm right.
Note:it will work with ONLY THAT SD card you made for it,because it uses the serial for encryption.
Just save it
Hi,brother!
I absolutely agree with you,that's the simpliest way and as we know:simple things always work.
Szig
The Following User Says Thank You to szig For This Useful Post:
Old 04-13-2010, 19:44   #10 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
Registry setting
On some devices you must set the right security permissions via Registry Editor:
HKLM/Security/Policies/Policies/"00001001' set to integer 1
Use registry editor or total commander for PPC or Resco explorer.
In Total commander you can find the registry under ///Plugins in the root of PPC.
After the setting you can make Goldcard.
QMAT manual:
4shared.com - document sharing - download QMATManual421.pdf
4shared.com - document sharing - download plugin-QMATManual500.pdf
Szig
The Following 7 Users Say Thank You to szig For This Useful Post:
Old 06-14-2010, 20:12   #11 (permalink)
Member: 1322753
Sonork: poelot
Thanks Meter: 3
much thanx on the information.
Old 09-29-2010, 06:38   #12 (permalink)
rajeshchiyyan's Avatar
Member: 1347585
Sonork: 100.1596390
Thanks Meter: 467
Question i have one dought brothers .,
Unbrick your device
i dnt't know how to do this steps .,? any one guide me detaily
Old 09-29-2010, 07:56   #13 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
Originally Posted by rajeshchiyyan View Post
Unbrick your device
Hi!
The bad news is:this is the detailed guide.
Open a new thread,give me details about your device and I will try to help you.
szig
Old 10-17-2010, 17:54   #14 (permalink)
Member: 1420467
hi,
If you dont have a winmo at hand but and android instread,
its possible to do a gold card also with an android phone
without qmat and without android sdk installed
for this method you
Must have
A windows pc (xp vista or 7)
htc sync installed (for drivers only)
sd card reader (optional)
a working android phone
(android sdk not required)
instructions:
download goldcard tools 0.5
here
GoldCardTools.zip - Wuala
download latest htc sync (get the latest for the android mobile model you are going to use)
here
Application - HTC Sync 3.0 for HTC Legend
after succesfull htc sync install
Format your sd card as Fat or Fat32 (Fat preferred if possible)
you can do this direcly in your phone or with a card reader
in your Pc with a format tool that allows Fat formatting as this one
here
Descargar HP USB Disk Storage Format Tool gratis
with the card formatted put it in your android phone
set it to usb debugging mode
(Menu/configuration/apps/development/usb depuration mode)
connect your android by USB to the pc AS DISK UNIT
and sync with HtcSync
when sync is done open gold card tools in Administrator mode
Click get cid button, if MMC1 does not bring the cid code try with MMC0
if successfull when cid code displayed generate gold card image
clicking at revskills link
Free HTC android goldcard generator | Phone System Analysis Software - PSAS
A GoldCard.zip image will be emailed to you within minutes.
Activate disk mode again in your phone, refresh and select the place
where the sd card is allocated, click load goldcard image and patch the MMC
Your Gold Card is ready.
Troubleshooting:
not all sd cards brands can be gold carded, try the minimun size possible
and kingston or Sand Disk brand if possible, regular old fashioned sd better
there are reports of big storage sdhc cards not valid
if you see
FAILED (remote: 42 custom id check fail)
the card is not valid or the process is not done correctly
if you see
Executing adb shell cat /sys/class/mmc_host/mmc0/mmc0:*/cid
Reading adb output
* daemon not running. starting it now *
* daemon started successfully *
Could not locate CID in output
then most likely abd cannot reach your android phone
try to sync again as disk mode but no recharging battery at same time
change fat32 to fat format
if an error comes patching the card try another one
the image is invisible as it patches sector 0 of the card, but its there
and you can continue using a gold card normally without any problem
once the gold car is correctly done you can introduce it in a bricked phone to
reflash a shipped rom or in your android to root it
Now,i need some help
im stuck with a bricked phone with and unlocked cid,
but i live in a small town so nobody around me knows what an htc is, nevertheless
what the hell is android...
so without a working phone i cannot create my own gold card
if somebody knows how to do it without phone just from a sd card reader
please let me know.
if someone know a valid link for an ELF01000 CID VODAP304 working shipped image i would aprecciate
or if someone lives in spain has a correctly done Gold card and allows me to borrow it for a while sending it to me by cheap mail so i can fix my phone,
i will ..aprecciate..i promise i will send it back.
thanks guys
Old 10-18-2010, 07:45   #15 (permalink)
Member: 319447
Thanks Meter: 4,949
@ kojikabuto
Its here buddy
http://forum.gsmhosting.com/vbb/f606...hones-1009439/
I need link to learn How to Make A Gsm Soft /unlock dr.motorola GSM Mobile Links 2 11-30-2001 12:22
how to make a ic2 bus cable and how to use? alro Hardware Repair by brands 4 06-20-2001 11:22
want to know how to make unlocked partial flash files wildwhacker Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-22-2001 18:36
i need to know how to make partial files wildwhacker Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-22-2001 18:34
need to know how to make partial flashes wildwhacker Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-22-2001 18:31
Page generated in 0.29862 seconds with 10 queries
