HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
12-15-2005, 08:05 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: INDIA Age: 43
Member: 75612 Status: Offline Thanks Meter: 1,427 | HERE IS NEW VERSION OF xda2unlock.exe v2.2 ,XDADEV_ALL_UNLOCK V1.6 Description: Version 2.2. The install tool that will install xda2unlock onto your device for you using ActiveSync. -------------------------------------------------------------------------- xda2unlock-v2.2.exe Description: Version 2.2. The basic PocketPC binary to install on your device yourself ------------------------------------------------------------------------------------------- Welcome to the Himalaya network lock repair tool! xda2unlock.exe v2.2 This tool installs a program on your Pocket PC called xda2unlock. It is installed in the \Program Files\XDA2Unlock directory. But you can also find it in under Programs in the Start menu. You need to tap on xda2unlock to execute it. A screen will appear informing you of the progress and any errors that might occor. When you are done you can remove the program under: Start -> Settings -> System -> Remove Programs -------------------------------------------------------------------------- HERE IS NEW VERSION OF XDA changelog v1.0: initial version v1.1: added PH20B1, PH10A v1.2: added PM10B ... contains BUG .. don't use v1.3: fixed bug, added PH20A1 - don't know if it will work. v1.4: unreleased ... v1.5: added PH10D, added code to clear remaining locks v1.6: resolves some of the stuck phone issues. -------------------------------------------------------------------------- SUPPORTED MODELS O2 XDA II (tested) O2 XDA IIs (tested) O2 XDA IIi (tested) O2 XDA II mini (tested) MDA Compact (tested) MDA II (tested) MDA III (tested) QTEK S100 (tested) QTEK 2020 (tested) QTEK 2020i (tested) QTEK 9090 (tested) SPV M500 (tested) SPV M1000 (tested) SPV M1500 (tested) SPV-M2000 (tested) i-Mate PDA2K (tested) i-Mate Jam (tested) i-Mate PDA2 (tested) Dopod 696 (tested) Dopod 699 (tested) Dopod 700 (tested) Dopod 818 (tested) Vodafone VPA-II (tested) Vodafone VPA-III (tested) Siemens SX66 (tested) Telefonica TSM500 (tested)Himalaya: PH10A PH10B Alpine: PH10C PH10D Magician: PM10A PM10B PM10C Blueangel: PH20B PH20B1 Last edited by rajan nishchal; 12-15-2005 at 09:04. |
The Following 13 Users Say Thank You to rajan nishchal For This Useful Post: |
03-29-2006, 15:44 | #4 (permalink) | |
Junior Member Join Date: Mar 2006
Member: 250888 Status: Offline Thanks Meter: 0 | Quote:
04-06-2006, 11:14 | #5 (permalink) |
Junior Member Join Date: Apr 2006
Member: 254573 Status: Offline Thanks Meter: 0 | no me funciona programa xda2unlock perdona no hablo ingles solo espaņol y aleman necesito ayuda tengo una pda i-mate jam he instalado nueva version sda2unlock y no me funciona , me pide codigo desbloqueo que tengo que hacer o estoy haciendo algo mal un saludo de espaņa ich spreche kein englich nur ein bishen deutch und spanich brauche hilfe ,habe i-mate jam und habe sda2unlock instaliert und funtzuniert nicht was muss ich machen danke und grusse aus spanien titi |
04-06-2006, 11:36 | #6 (permalink) | |
No Life Poster Join Date: Jun 2003 Location: kinshasa, D.R.C. Age: 59
Member: 31246 Status: Offline Thanks Meter: 54 | Quote:
04-06-2006, 12:30 | #7 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Nederlands / Germany / Danmark Age: 51
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | I translate for todojose Hi, i don`t speak english, only spanisch and a little german. I need help. I have an i_mate jam and just installed sda2unlock but it doesn`t work for me. what should i do??? Please help me. Best regards from Spain |
04-06-2006, 13:13 | #8 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
xda2unlock-v2.2.rar IN RAR YOU GET ONE EXE.........YOU HAVE TO COPY THAT EXE TO MMC...BECUSE IF YOU COPY IT VIA ACTIVESYC IT WILL CONVERTED .......SO DON'T WORED.....USE MMC OPEN VIA FEXPLORER AND PHONE WILL UNLOCK IN FEW SECONDS........ | |
06-18-2006, 17:03 | #12 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 296041 Status: Offline Thanks Meter: 0 | m1500 problem Can you help please I have m1500 that is locked and asking for unlock code. I tried to unlock using software from a ebay vendor but it has only got this far. any way I can load this software to run and unlock. New to this tx alan b Quote:
07-04-2006, 14:44 | #13 (permalink) |
Junior Member Join Date: Jul 2006
Member: 305621 Status: Offline Thanks Meter: 0 | Hello GSM-Forum community! This is actually a two-part question: First, this ought to work to do a network unlock on a QTEK 2020 correct? Second, where can I get that so called ActiveSync software ? Is that the Microsoft 4.1 version available on Microsoft's site? Thx in advance and best regards |
07-05-2006, 01:42 | #14 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: New York City, USA Age: 58
Member: 56365 Status: Offline Thanks Meter: 28 | Quote:
I've never tried with a TEK 2020 but here is a link in this forum in reference to unlocking it: http://forum.gsmhosting.com/vbb/show...75&postcount=6 And Active sync from Microsoft..... http://www.microsoft.com/downloads/d...DisplayLang=en Regards, JOHNNY. | |
07-20-2006, 10:27 | #15 (permalink) |
Product Manager Join Date: Feb 2003 Location: Your Exclusive Source
Member: 20645 Status: Offline Sonork: 100.1579175 Thanks Meter: 635 | my dopod have problem it came from uk but it ask owner code how to reset it while reseting not work mean like we did in imate etc... it not boot and to change owner information need urgent help REGARDS GSM MIND |
here is New version of e90 EMEA_dp4.0_sw07.40.1.2 | DeDo Gsm1911 | Nokia Base Band 5 ( BB-5 ) | 2 | 08-19-2010 09:31 |
HERE is new version of EF51 to be supported | tsarkh | Infinity-Box | 1 | 02-06-2008 13:38 |
