Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2006 Location: Hungary Age: 46
Member: 365452 Status: Offline Thanks Meter: 838 | How to make a GOLDCARD Finally,I made this guide to show you how to create Goldcard.It’s not my creation,I just collected the informations.I tried to link the original source everywhere. All credit goes to the original authors,programmers,etc…. What is a Goldcard? A Gold Card is a memory card that has been converted to unlock your device's CID while it is in bootloader mode. Goldcard is limited,you can use it 2 times,after that you have to generate a new one. Info: http://wiki.xda-developers.com/index...e=Elf_GoldCard Why do you need it? If you have a semi-bricked device (doesn’t boot up,but you have bootloader) and you can’t find the matching CID ROM. Sometimes it helps when you can’t flash your device properly,it stuck in bootloader after flash or just sometimes gives error during the upgrade.It’s my experience,it worked for me many times,but no one else confirmed that. Anything you do,you do it at your own risk,I take no responsibility for any damaged,bricked device! What we need for Goldcard: -micro SD card (64MB-512MB) -card reader -QMAT software (my example is with version 5.06 TRIAL,NOTE:Trial version works for 10 minutes only!It's enough,Goldcard generating takes seconds.You can generate Goldcard for older devices only,for newer devices you have to buy the software.See the bottom of the page.) -a working Windows Mobile device Format your memory card for FAT32 If you have a card reader, go to DOS and type: format <volume> /FS:FAT32 /A:4096 where <volume> specifies the drive letter of the SD card. For example: format d: /FS:FAT32 /A:4096
Run QMAT to create the Gold Card My example is a Charmer Goldcard Put the newly-formatted SD card in the working WM device and connect to Activesync Run QMAT, go to the Hardware Forensics menu, and then select "Generate HTC Goldcard" Select your bricked device's key Get the SD Card Serial from WINCE Device (or enter it manually if you already have the Card ID) Save the Gold Card image to the SD Card Unbrick your device Go to bootloader mode on your device with inserted Gold Card. Disable USB connections in Activesync settings menu.Connect your device to your PC. From your PC, run the RomUpdateUtility.exe from the RUU folder containing the shipped ROM Alternatively, you can rename the shipped ROM (NBH file) to "XXXXIMG.nbh" (where XXXX is related to the model,for example:ARTEIMG,KAISIMG,etc...)and copy to your SD card, and then reboot your device to bootloader. It should start flashing if everything is configured properly! If everything went fine,the only thing you have to do is:enjoy your unbricked,running device! About QMAT:It's NOT an advertissement,I'm NOT related to that company! If you like and need this software (to generate Goldcard to newer devices) then buy it! http://psas.revskills.de/ Download Qmat PHP Code: PHP Code: Last edited by ..::Neo::..; 10-18-2012 at 02:13. Reason: Link added |
The Following 30 Users Say Thank You to szig For This Useful Post: |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Bangladesh Age: 41
Member: 319447 Status: Offline Thanks Meter: 4,948 | Thread added to Sticky Post only Gold Card related question in this thread. All other posts will be deleted. |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
![]() | #9 (permalink) | ||
Member: 365452 Status: Offline Thanks Meter: 838 | Quote:
Note:it will work with ONLY THAT SD card you made for it,because it uses the serial for encryption. Quote:
I absolutely agree with you,that's the simpliest way and as we know:simple things always work. BR Szig | ||
The Following User Says Thank You to szig For This Useful Post: |
![]() | #10 (permalink) |
Member: 365452 Status: Offline Thanks Meter: 838 | Registry setting On some devices you must set the right security permissions via Registry Editor: HKLM/Security/Policies/Policies/"00001001' set to integer 1 Use registry editor or total commander for PPC or Resco explorer. In Total commander you can find the registry under ///Plugins in the root of PPC. After the setting you can make Goldcard. QMAT manual: 4shared.com - document sharing - download QMATManual421.pdf 4shared.com - document sharing - download plugin-QMATManual500.pdf BR Szig |
The Following 7 Users Say Thank You to szig For This Useful Post: |
![]() | #12 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jul 2010 Location: MobilesFactory,trichy,TN,India Age: 32
Member: 1347585 Status: Offline Sonork: 100.1596390 Thanks Meter: 467 ![]() | ![]() Unbrick your device Go to bootloader mode on your device with inserted Gold Card. Disable USB connections in Activesync settings menu.Connect your device to your PC. From your PC, run the RomUpdateUtility.exe from the RUU folder containing the shipped ROM Alternatively, you can rename the shipped ROM (NBH file) to "XXXXIMG.nbh" (where XXXX is related to the model,for example:ARTEIMG,KAISIMG,etc...)and copy to your SD card, and then reboot your device to bootloader. It should start flashing if everything is configured properly! If everything went fine,the only thing you have to do is:enjoy your unbricked,running device! i dnt't know how to do this steps .,? any one guide me detaily ![]() |
![]() | #13 (permalink) | |
The bad news is:this is the detailed guide. Open a new thread,give me details about your device and I will try to help you. BR szig | |
![]() | #14 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1420467 Status: Offline Thanks Meter: 0 | hi, If you dont have a winmo at hand but and android instread, its possible to do a gold card also with an android phone without qmat and without android sdk installed for this method you Must have A windows pc (xp vista or 7) htc sync installed (for drivers only) sd card reader (optional) a working android phone (android sdk not required) instructions: download goldcard tools 0.5 here GoldCardTools.zip - Wuala download latest htc sync (get the latest for the android mobile model you are going to use) here Application - HTC Sync 3.0 for HTC Legend after succesfull htc sync install Format your sd card as Fat or Fat32 (Fat preferred if possible) you can do this direcly in your phone or with a card reader in your Pc with a format tool that allows Fat formatting as this one ![]() here Descargar HP USB Disk Storage Format Tool gratis with the card formatted put it in your android phone set it to usb debugging mode (Menu/configuration/apps/development/usb depuration mode) connect your android by USB to the pc AS DISK UNIT and sync with HtcSync when sync is done open gold card tools in Administrator mode ![]() Click get cid button, if MMC1 does not bring the cid code try with MMC0 if successfull when cid code displayed generate gold card image clicking at revskills link Free HTC android goldcard generator | Phone System Analysis Software - PSAS ![]() A GoldCard.zip image will be emailed to you within minutes. ![]() Activate disk mode again in your phone, refresh and select the place where the sd card is allocated, click load goldcard image and patch the MMC ![]() Your Gold Card is ready. Troubleshooting: not all sd cards brands can be gold carded, try the minimun size possible and kingston or Sand Disk brand if possible, regular old fashioned sd better there are reports of big storage sdhc cards not valid if you see FAILED (remote: 42 custom id check fail) the card is not valid or the process is not done correctly if you see Executing adb shell cat /sys/class/mmc_host/mmc0/mmc0:*/cid Reading adb output ------------------------ * daemon not running. starting it now * * daemon started successfully * ------------------------ Could not locate CID in output then most likely abd cannot reach your android phone try to sync again as disk mode but no recharging battery at same time change fat32 to fat format if an error comes patching the card try another one the image is invisible as it patches sector 0 of the card, but its there and you can continue using a gold card normally without any problem once the gold car is correctly done you can introduce it in a bricked phone to reflash a shipped rom or in your android to root it Now,i need some help im stuck with a bricked phone with and unlocked cid, but i live in a small town so nobody around me knows what an htc is, nevertheless what the hell is android... ![]() so without a working phone i cannot create my own gold card if somebody knows how to do it without phone just from a sd card reader please let me know. if someone know a valid link for an ELF01000 CID VODAP304 working shipped image i would aprecciate or if someone lives in spain has a correctly done Gold card and allows me to borrow it for a while sending it to me by cheap mail so i can fix my phone, i will ..aprecciate..i promise i will send it back. ![]() thanks guys ![]() Last edited by kojikabuto; 10-17-2010 at 18:01. |
I need link to learn How to Make A Gsm Soft /unlock | dr.motorola | GSM Mobile Links | 2 | 11-30-2001 12:22 |
how to make a ic2 bus cable and how to use? | alro | Hardware Repair by brands | 4 | 06-20-2001 11:22 |
want to know how to make unlocked partial flash files | wildwhacker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-22-2001 18:36 |
i need to know how to make partial files | wildwhacker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-22-2001 18:34 |
need to know how to make partial flashes | wildwhacker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-22-2001 18:31 |
