How to reset htc kais(130) sir i have on HTC (KAIS 130) PLZ ANY ONE TELL ME HOW HARD RESET. IT. I NEED URGENT HELP PLZ DONT IGNORE IT I CHECK THREAD. THAT SHOWS ALL HERD RESET BUT COULDEN FIND THERE ABOUT HTC KAIS 130 HARD REST. PLZ HELP NEED URGENT HELP FROM ANY ONE WHO KNOW EXACT PROCEDURE . |
* Press and hold both soft keys * Using a stylus, press and hold the soft reset button at the bottom of the phone * Keep all three buttons pressed until the keypad lights turn off and then flash * Release the soft reset button while still pressing the soft keys * Let go of the two soft keys once the message "This operation will delete all your personal data, to manufacturer default" appears on screen * Finally, press the green call button to perform the hard reset, or press other key to cancel |
Do what i did Use 2 pens to hold down the soft keys and then press soft reset with stylus or get someone else to soft reset it while you hold the soft keys with the pens. I tried for hours with my fingers before I did it with the pens, hope this helps |
i did it and its working 1000000000000% thanks for help |
me to bro i test it working 100%thanks allot bro |
thanks its working.... |
its working 100%.if u r having trouble turn ur phone on and then hard reset ur phone |
working 1000/100 thanks |
sam-man you are perfect tanks a lot |
Thanks so much this method is tested and working 100% i also tried many time before but no success so left phone after power off and picked after half hr approx then i pressed left and right soft keys and turned on the phone so this sow me the data eras message. conformed with green dial key and done. |
