HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
12-04-2013, 16:46 | #1 (permalink) |
Junior Member Join Date: Feb 2013
Member: 1879919 Status: Offline Thanks Meter: 0 | HTC HD2 boot problem I post again here: Hi, I found no one case like the mine on internet, so I hope you can help me! I've a HTC HD2 T8585. I don't know anything about his previous life, so I don't know why now is on that conditions. When I power on the phone, a grey screen with this written on: flash type 5510BCAD power reason 1 BOOTUP_W_PWR_KEY_PRESSED Nothing else happen. I've try to flash via sd-card a original rom, downloaded directly from htc. The update success, but still same situation. If I go in download mode, I see: PB81100 HX-BC SPL-1.42.0000 XE MicroP(LED) 0x05 MicroP(TOUCH) 0x50 Sometimes, apparently casually, the phone vibrate 6 times. Just 2 times the phone has started, but when all is loaded, I see that touch screen doesn't work. If I restart the phone, the same problem (flash type ecc) happen. So I don't know.. probably a wrong rom has been installed? what can I do? I'm from Italy, and I would to revive this phone, indifferently with wf or with android! **UPDATE* I've try to install the hspl 2.08. I've followed the procedure for installing the andoid OS, but while flashing magldr, I can't view its menu in the phone, so I can't continue the flashing procedure. What do you think? will be possible revive the phone without a box? (i've octopus samsung-lg and atf, but nothing for htc) Please help me! Thank you very much! |
