O2 Xphone II, How to Hard Reset? Plz Help!! Anyone please tell me how to hard reset the O2 Xphone II phone? The phone is freezed at Window Mobile page.. I believe it needs hard reset or does anyone know the problem? Thanks |
press soft reset and while keep pressed pres power-on.release buttons |
Can you tell me where is the soft reset button?. This is the Xphone II, not the XDA II...I see a small hole at the left bottom but maybe it's MIC hole? plz tell me ,thanks |
try to hold pressed the two soft key and power phone maybe appear message like press 0 for factory default or other key to exit. |
that does not work, if you know other way, plz help thanks |
How to get application software, to make better phone. |
Put Out Your Phon's Battery For Two Or Three Hours. Then Insert It Into The Phone And Power On It. Enjoy ;) |
release power-on.:D :D :D :D :D |
Here is the Procedure: O2 Xphone 2 / Xphone 2M, SDA / Like those: 1. Turn off your xphone 2. press and hold left + right soft menu key 3. while still holding left+right soft menu key, press the on/off button ONCE and RELEASE. 4. keep left + right soft key pressed until you see the message: "Press 0 to restore fatory setting, other key to quit" 5. press 0 and wait for the phone to boot up, the restoring of factory default will begin and will ask to reboot your phone when done.:cool: |
