05-19-2013, 11:45 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: BANGLADESH Age: 43
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Tell me any Walton Android Phone problem.i will Try to solve it only in one hour Tell me any Walton Android Primo series Phone software problem.i will Try to solve it only in few hour [IMG]http://3.bp.********.com/-5pp03GYxnc0/USMqqYXvZxI/AAAAAAAAIPc/iqmpmchffXM/s1600/Walton-Primo-G2.png[/IMG] tell me details what you need example: u need firmware & update tools |
The Following 28 Users Say Thank You to helpful-man For This Useful Post: |
05-19-2013, 11:57 | #2 (permalink) |
No Life Poster Join Date: Feb 2012 Location: dhaka,bangladesh Age: 35
Member: 1721085 Status: Offline Sonork: WHATSAPP +8801922938928 Thanks Meter: 116 | bro need firmwer and tools.pls share me |
The Following User Says Thank You to recekeshgosh For This Useful Post: |
05-19-2013, 13:56 | #3 (permalink) |
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Walton Primo N1 Software, Flashtools and Drivers 1. Install driver. 2. Open Flash Tool 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading and select scatter file Software-> WBW5883WA_0301_T5393 -> MT6589_Android_scatter_emmc.txt 5. Click Firmware->Upgrade and connect USB cable with mobile without battery 6. Insert Battery then start downloading.. 7. When it shows Firmware Upgrade , then installation is completed. After Firmware Upgrade give Reset to Factory Setting FILE DOWNLOAD |
The Following 20 Users Say Thank You to helpful-man For This Useful Post: |
05-19-2013, 14:04 | #4 (permalink) |
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Walton Primo X1 Software, Flashtools and Drivers 1. Install driver. 2. Open Flash Tool 3. Open Download Agent and select MTK_AllinOne_DA 4. Open scatter_loading and select scatter file Software-> WBWS305WA_0201_T5056 -> MT6589_Android_scatter_emmc.txt 5. Click Firmware->Upgrade and connect USB cable with mobile Off 6. Then start downloading.. 7. When it shows Firmware Upgrade , then installation is completed. After Firmware Upgrade give Reset to Factory Setting FILE & TOOLS DOWNLOAD |
The Following 25 Users Say Thank You to helpful-man For This Useful Post: |
05-21-2013, 09:43 | #5 (permalink) |
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Walton Primo R1 Software, Flashtools and Drivers |
The Following 4 Users Say Thank You to helpful-man For This Useful Post: |
05-21-2013, 11:04 | #6 (permalink) |
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | WALTON Primo G2 Software update (AP+BP) Guide Driver installation 1) Install AP part driver Power off handset, press “Power key + Voice Up key” until the screen shows green, plug in usb cable, PC will remind you of installing new hardware. Unzip “ Driver”, select adb driver file, install AP driver. Path: Right click on My computer>Manage>Device manager>Android(Yellow notification)>Update driver software>browse path> select adb folder >Continue anyway>finish When you install AP driver successfully, you will find “Fastboot interface” in device manager. As below 2) Install BP part driver (i) Power off handset, press “Power key + Voice Down key” until the screen shows QPST mode, plug in 5Pin USB cable, Unzip “Driver”, select HK11-VB717-27_1.0.56 driver file, install BP driver. Path: Right click on My computer>Manage>Device manager>Tiyanyu HS-USB Driver (Yellow notification)>Update driver software>browse path> HK11-VB717-27_1.0.56\Win32\x86\free >Continue anyway>finish. (ii) When your BP driver is installed successfully, you will find Qualcomm HS-USB ports in device manager. As below: Software Upgrading: 1.Download BP Open Primo Download V1.2.3 tool, set your handset into BP mode (Power key+ Voice down key) and connect your phone with USB cable. 1. Click set path>Browse folder>Select 592522_8550_WCDMA_V000001 2. Click Download All 2.AP Download: Open Primo Flasher V1.0 tool, set your handset into AP mode (Power key+ Voice up key) and connect your phone with USB cable. . 1. Click Set path>Browse folder>Select 592522_8550_V001006 2. Click Ok for Start download. Note: If your antivirus detects Primo Flash Tool as virus, disable your antivirus till software is finish. GO |
The Following 9 Users Say Thank You to helpful-man For This Useful Post: |
05-25-2013, 08:11 | #9 (permalink) | |
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Quote:
The Following 5 Users Say Thank You to helpful-man For This Useful Post: |
06-01-2013, 10:59 | #11 (permalink) |
Junior Member Join Date: Nov 2009 Location: pk
Member: 1153789 Status: Offline Thanks Meter: 4 | dear tell me how can i root htc one clone below link of the phone HTC One Clone China Mobile Named iHTC One Features, Price and Specs click below link http://asf-mobiles.net/htc-one-clone...ice-and-specs/ |
The Following User Says Thank You to altafali For This Useful Post: |
06-02-2013, 12:50 | #12 (permalink) | |
here your solution go | |
The Following 3 Users Say Thank You to helpful-man For This Useful Post: |
06-03-2013, 08:02 | #13 (permalink) |
Insane Poster Join Date: Feb 2013
Member: 1877162 Status: Offline Sonork: 100.1603065 Thanks Meter: 8 | ZTE V875 (telenor) hand on android logo -------------------------------------------------------------------------------- Please help how to solve this problem Info is here:- Connected Receiving phone info Getting phone info Model: V875 Platform: ZTE Qualcomm Software Platform: Android CPU: Qualcomm Firmware Released: Mar 1 2012 09:30:22 Firmware Compiled: Oct 26 2010 14:00:00 Firmware Version: M76XX-TSNCJOLYM-6050/TSNCJOLY IMEI: 861071-xx-xxxxxx-x Connect mode: Normal Info received |
The Following User Says Thank You to irfan_mob_lab For This Useful Post: |
06-03-2013, 09:56 | #14 (permalink) | |
go | |
The Following User Says Thank You to helpful-man For This Useful Post: |
06-03-2013, 12:06 | #15 (permalink) |
Member: 1306751 Status: Offline Sonork: 100.1604993 Thanks Meter: 4,916 | Software Flashing Instructions for Primo-C1 Software Flashing Instructions for Primo-C1 1. Double click Setup.exe to install the driver. 2. Double click ResearchDownload.exe and open the flashing tool. 3. Click the first button, select the correct .pac file and confirm. 4. Click the third button to get ready to start. 5. Connect the handset to PC with USB data cable, Long press volume down key and insert the battery. Now it starts to install the software. 6. When it shows Passed in green, the installation is completed. DOWNLOAD |
