07-03-2013, 22:45 | #1 (permalink) |
Super Moderator Join Date: Nov 2008 Location: Bangladesh<>Türkiye
Member: 1435864 Status: Offline Sonork: / Skype id: Parashsky Thanks Meter: 1,755 | Walton primo H1 Root and CWM recovery Lets do this: Download the Framaroot.apk from here . install it on your phone, Click Gandlaf to root. Reboot your Phone Isn't it very simple !!!! to root your primo H1 Note: It may void your warranty, i will not responsible for your any kind of damage of your phone BR. |
The Following 3 Users Say Thank You to Parash For This Useful Post: |
07-03-2013, 22:47 | #2 (permalink) |
Member: 1435864 Status: Offline Sonork: / Skype id: Parashsky Thanks Meter: 1,755 | CWM recovery for walton primo H1 CWM recovery for walton primo H1 # Install driver Driver installation 1) Install AP part driver Power off handset, press “Power key + Voice Up key” until the screen shows green, plug in usb cable, PC will remind you of installing new hardware. Unzip “ Driver”, select adb driver file, install AP driver. Path: Right click on My computer>Manage>Device manager>Android(Yellow notification)>Update driver software>browse path> select adb folder >Continue anyway>finish When you install AP driver successfully, you will find “Fastboot interface” in device manager. 2) Install BP part driver (i) Power off handset, press “Power key + Voice down key” until the screen shows QPST mode, plug in 5Pin USB cable, Unzip “Driver”, select HK11-VB717-27_1.0.56 driver file, install BP driver. Path: Right click on My computer>Manage>Device manager>Tiyanyu HS-USB Driver (Yellow notification)>Update driver software>browse path> HK11-VB717-27_1.0.56\Win32\x86\free >Continue anyway>finish. (ii) When your BP driver is installed successfully, you will find Qualcomm HS-USB ports in device manager. 2nd step: download ” recovery.img “ and “Android AIO Flasher” file from here 4. Go to Fastboot mode in your phone by pressing Volume up + power key together ( Green Screen) 5. Connect your phone into PC via USB cable 3. Open “Android AIO Flasher” 5. Select recovery > Select file > Flash Done!!! CWM recovery is successfully installed in your Walton Primo H1 BR. |
The Following 4 Users Say Thank You to Parash For This Useful Post: |
