Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Falcon Box by Miracle Team
Old 06-27-2018, 14:18   #1 (permalink)
chinchik's Avatar
Member: 145494
Sonork: 100.111656
Thanks Meter: 18,407
Falcon Box HTC ANDROID TOOL V2.0 World's First Features [27/06/2018]
Falcon Box
Next Generation Mobile Tool
iNNOVATED BY MIRACLE TEAM
Version 2.0 (27TH JUNE 2018)
Thanks for Using Miracle Team Product “Falcon Box & Falcon Miracle Key Edition
To make the Better Mobile Repair Solution for you, We bring to the Updates regularly.
Every Update of our software include improvements for new functions and better service
and reliability.
Falcon Box HTC ANDROID TOOL V2.0 Highlights
[+] Can Available on Miracle key Activation
Added
[+] Auto Authorization No need Login
[+] HTC Mtk Frp Removal in Flash Mode
- Remove Frp In Flash Mode
[+] Enable Usb Debug for Frp Removal
- Enable Adb For Frp Removal
[+] Remove Frp In Adb Mode
- Remove Frp In Adb Mode
[+] Ruu Analyse, Encrypt/Decrypt
- Analyse, Encrypt/Decrypt Ruu Files
[+] Partition Dump for Mtk HTC Devices
Dump Any Single Partition in Flash Mode or Adb Mode
Possible to get all software and hardware information like:
# OTA
# Factory Build
# CPU Specification
# Default
# Nand IC
# Original Equipment Manufacturer
# Kernel
# System
# Can show similar devices and hard reset guides
# Can Detect Model automatically
[+] S-OFF Section
Ability to Disable Hboot Security(S-OFF) for this models: (only in normal mode)(radio lock not change)
And Super CID for:
HTC One s(s4 series)
[+] Root Tool
Temporarily and perm root by 6 different method in normal mode.
[+] GoldCard Section
# Ability to create goldcard (new and old phone) and write it and store it on computer
# (stand alone – so you can flash any device without need s-off) –> (World’s First)
# Ability Direct Gold-card writing on SDcard for PC
[+] Easy Update & Recovery Section
# Downgrade and upgrade original ROM available by one click
# (no need to select files for supported models)
(for who users installed Full Setup) –> (World’s First)
# Custom recovery installation with one click
(no need to select the files under supported models)
# Custom ROM installation with support for all languages with one click
# (no need to select the files under supported models)
# Custom Kernel installation with one click
[+] Generic Read Codes / Direct Unlock for HTC Mtk Devices
# Read Simlock Status
# All HTC SPRINT/Virgin Unlock (With or without Root)
# All HTC SPRINT/Virgin Read Msl/Spc (With or without Root)
# All HTC Android Enable All Languages without Flash (Need Root)
# HTC Mtk Cid Changer
# 111 Different Themes
[+] Manual Flash & Dump,Erase
# Manual Flash, files can be Boot – Recovery – System – Userdata – Hboot.
# Manual Flash in normal mode, files can be Misc – Recovery –> (World’s First)
# Dump possible from the system partition and display the operating system map –> (World’s First)
# Auto Flash ZIP/OTA Package in Recovery mode –> (World’s First)
# Partition dumping for All partitions and All Android devices in Normal&Recovery mode(HTC,Samsung,LG,Motorola,ZTE…)
[+] Advance Function Section
# Change CID – MID – Serial (in-state S-OFF)
# Possible to boot the phone with the desired file
Erase all the possible partitions –> (World’s First)
# Change main versions with manual method just one click (for downgrade – no need S-OFF) –> (World’s First)
# Change main versions with auto method just one click (for downgrade – no need S-OFF) –> (World’s First)
Ability to fix USB Brick –> (World’s First)
[+] Application Section
# Ability to install APK software (mass installation) and
display file info with ability to the install on external memory
# Uninstall application(apk) on the operating system
[+] Misc section
# Google Account Bypassing just with one click(Normal and Custom Recovery) –> (World’s First)
# Ability to change phone mode automatically (HBoot – Recovery – Fastboot – Ruu mode)
# Possible activation App2SD WITHOUT ROOT (for installing software on the External Storage – version 2.1 and up) –> (World’s First)
# Wipe off the System – Cache – UserData
# Possibility of temporarily and permanently activate the USB Debug (for HTC mobile phones ) –> (World’s First)
# Ability to remove Password – Pin – Pattern without losing user data(all brands) –> (World’s First)
# The ability to Easy and Fast unlock the boot loader for HTC
# The ability to Easy and Fast unlock the boot loader for Motorola
# The ability to Easy and Fast unlock the boot loader for Google
# The ability to Easy and Fast unlock the boot loader for Sony
# The ability to Easy and Fast unlock the boot loader for SonyEricisson
[+] MTK HTC Devices
# MT6572
# MT6573
# MT6577
# MT6582
# MT6589
# MT6592
# MT6595
# MT6732
# MT6735
# MT6752
# MT6753
# MT6795
[+] Added Write Scatter
# Added Factory flash support for old scatters type
# Added Partition Dumping for Following MTK Chipsets
# Added Format and Erase for MTK devices
# Added Scatter(old and new type) creator on DA Mode(boot mode) for MTK devices
# Added CPU auto detection for MTK devices
BR [SV]'S MIRACLE TEAM
The Following 17 Users Say Thank You to chinchik For This Useful Post:
Old 06-27-2018, 14:19   #2 (permalink)
chinchik's Avatar
Member: 145494
Sonork: 100.111656
Miracle Falcon Activation Available for Miracle Key
# No Need Login Auto Login
# All Free Packs Available
# No Need buy Other Dongle or Card
This is Summer Offer any time will Stop.
The Following 5 Users Say Thank You to chinchik For This Useful Post:
Old 06-27-2018, 14:19   #3 (permalink)
chinchik's Avatar
Member: 145494
Sonork: 100.111656
Post reserved for team news post etc......
The Following User Says Thank You to chinchik For This Useful Post:
Old 06-27-2018, 16:26   #4 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
Only mtk htc or any other soff
Old 06-27-2018, 18:22   #5 (permalink)
Member: 2703335
Thanks Meter: 22
can this tool s-off htc one mini 2, htc one x, htc one v?
Old 06-28-2018, 00:02   #6 (permalink)
YOUSIF ADAM77's Avatar
Member: 2788608
Sonork: 0912966232
Thanks Meter: 26
thanks for good update ........
Old 06-28-2018, 11:18   #7 (permalink)
Member: 2340647
Thanks Meter: 69
Pls Whats The Problem????
The Following 2 Users Say Thank You to wahby4 For This Useful Post:
Old 06-28-2018, 15:15   #8 (permalink)
Member: 2552533
Thanks Meter: 93
great update keep it up team
Old 06-29-2018, 10:29   #9 (permalink)
Member: 120579
Thanks Meter: 182
HTC 10 network unlock supported ?
Old 07-01-2018, 20:58   #10 (permalink)
Member: 19271
Thanks Meter: 17
Any chance to add support HTC M9e (MTK MT6795T)?
Of course I run FHM as Administrator
I try dump partition and now looks like this:
Establishing secured session...
Session Established..
Loading Scatter File...
Elapsed: 0 seconds
Dump configuration failed,run as administrator or try again
Elapsed: 0 seconds
Creating MTK scatter file...
Getting Device partition map...
Power off device then connect to usb cable or reboot device
Scanning USB port...
Searching for USB device...
USB port is obtained. path name(\\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5d cbf10-6530-11d2-901f-00c04fb951ed}), port name(MediaTek PreLoader USB VCOM (Android) (COM29))
USB port detected: \\?\usb#vid_0e8d&pid_2000#5&17864ebc&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Detecting Device chipset...
Target cpu type is MT6795
HOLD POWER BUTTON ON DEVICE FOR "10 SECOND" TO RESTART BOOTLOADER
Elapsed: 14 seconds
Elapsed: 0 seconds
Elapsed: 0 seconds
Elapsed: 0 seconds
Failed to Connect DA: S_BROM_DOWNLOAD_DA_FAIL
Uncaught BaseException in main(): BROM ERROR : S_BROM_DOWNLOAD_DA_FAIL (2004)
hw_ver(0xCA00), sw_ver(0x0000), hw_code(0x6795), hw_subcode(0x8A00)
Failed to get partition map
Failed to get Scatter File
Scatter file looks good, extracted from ROM by ruu_decrypt_tool.
Anyway I try to dump scatter from phone, without success.
Old 07-02-2018, 12:34   #11 (permalink)
Member: 2137463
Good wishes team Falcon. A query I bought a dongle, but I could not use the smart card in any way or activate it, I tried everything and nothing, have another and if it works very well, but it is last it came to yes me defective. Any solution this time?
Old 07-19-2018, 19:14   #12 (permalink)
Member: 870866
Thanks Meter: 51
Does Falcon Box Unlock HTC Desire 820s?
Old 07-20-2018, 13:56   #13 (permalink)
Member: 2364256
Sonork: 100.1676491
Thanks Meter: 15
Can This unlock HtC one.........?
Old 07-20-2018, 21:27   #14 (permalink)
Member: 1357353
Thanks Meter: 5
nice update
thank you falcon Team
Page generated in 0.29024 seconds with 8 queries
