Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Falcon Box by Miracle Team
Old 11-25-2016, 14:54   #1486 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Falcon Box Successfully Reports & Posts
Lyf Flame 1 Imei Rebuild (Both ) Done One Click With
Falcon
The Iron-Man
The Following User Says Thank You to ::kisna:: For This Useful Post:
Old 11-25-2016, 14:56   #1487 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Lyf Ls-5010 Dead Recovered With Flash By
Falcon
The Iron-Man
Old 11-25-2016, 14:57   #1488 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Talking Falcon Box Successfully Reports & Posts
Moto Xt-1033 Stuck Solved With Flash By
Falcon
The Iron-Man
Old 11-25-2016, 15:00   #1489 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Redmi 2 Prime Stuck Solved With Flash By
Falcon
The Iron-Man
Old 11-26-2016, 04:08   #1490 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Htc 826g dual sim stuck on logo solved with flash
Falcon™
The Iron-Man Effect
Old 11-26-2016, 06:16   #1491 (permalink)
DALIM SARKAR's Avatar
Member: 1703431
Sonork: 100.1619192 QQ 3271159180
Thanks Meter: 2,106
Samsung SM-J120G (Galaxy J1) 2016 Unlock Done By Falcon Box
Old 11-27-2016, 06:41   #1492 (permalink)
idrish911's Avatar
Member: 1497850
Sonork: 100.1601368 QQID:21952428
Thanks Meter: 1,575
MI NOTE 3 THIS DEVICE IS LOCKED REMOVED BY FALCON
SUCESS WITH FALCON
MIRACLE TEAM
IDRISH911
Old 11-27-2016, 07:05   #1493 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
micromax a092 both imei rebuild done one click with
Falcon
Still Waitting For .........
Old 11-27-2016, 07:06   #1494 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Htc D728W Enable Adb Done One Click With
Falcon
Old 11-27-2016, 07:08   #1495 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Another Flame One Stuck Solved With Simple Qcm Flash By
Falcon
Old 11-27-2016, 07:09   #1496 (permalink)
::kisna::'s Avatar
Member: 2643267
Thanks Meter: 378
Mi Redmi 2 Prime Stuck Solved With Flash By
Falcon
Old 11-27-2016, 09:20   #1497 (permalink)
Member: 1868800
Sonork: 100.1625792
Thanks Meter: 2,344
Samsung J2 6 SM-J210F
FRP Lock Easily Reset By Write Combination File (ADB Mode)
With Falcon Box Powered By Miracle Team
First Write Combination File
Second Reset FRP Lock Via (Samsung 2016 Method 2)
Br,
Old 11-28-2016, 07:15   #1498 (permalink)
Member: 1971123
Sonork: 100.1661727
Thanks Meter: 555
Arrow Falcon Box Successfully Reports & Posts
SAMSUNG SM-A510FD STUCK ON KISE MODE RECOVERY BY FLASH
REAL
MULTI TOOL
Galaxy A5 (2016)
Old 11-28-2016, 07:37   #1499 (permalink)
Member: 1703431
Thanks Meter: 2,106
Old 11-28-2016, 08:28   #1500 (permalink)
ATHI's Avatar
Member: 667142
Sonork: +919655528882
Thanks Meter: 2,479
Lenovo A6000 Qualcomm MSM8916 Hang On Logo Recover Done
BY
Falcon Box ( Qualcomm Flasher )
Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Login.. ok Hint: Connect Now Phone in Fastboot Mode.. Waiting for Phone... Phone Found.. Read Info Skipped..
Partition : modem Filename : NON-HLOS.bin StartAddress : 0x4000000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : modem Size : 47921 KB Verifying.. ok Writing : modem Verifying.. ok Done..
Partition : sbl1 Filename : sbl1.mbn StartAddress : 0x8000000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : sbl1 Size : 244 KB Verifying.. ok Writing : sbl1 Verifying.. ok Done..
Partition : sbl1bak Filename : sbl1.mbn StartAddress : 0x8080000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : sbl1bak Size : 244 KB Verifying.. ok Writing : sbl1bak Verifying.. ok Done..
Partition : aboot Filename : emmc_appsboot.mbn StartAddress : 0x8100000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : aboot Size : 462 KB Verifying.. ok Writing : aboot Verifying.. ok Done..
Partition : abootbak Filename : emmc_appsboot.mbn StartAddress : 0x8200000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : abootbak Size : 462 KB Verifying.. ok Writing : abootbak Verifying.. ok Done..
Partition : rpm Filename : rpm.mbn StartAddress : 0x8300000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : rpm Size : 147 KB Verifying.. ok Writing : rpm Verifying.. ok Done..
Partition : rpmbak Filename : rpm.mbn StartAddress : 0x8380000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : rpmbak Size : 147 KB Verifying.. ok Writing : rpmbak Verifying.. ok Done..
Partition : tz Filename : tz.mbn StartAddress : 0x8400000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : tz Size : 472 KB Verifying.. ok Writing : tz Verifying.. ok Done..
Partition : tzbak Filename : tz.mbn StartAddress : 0x8480000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : tzbak Size : 472 KB Verifying.. ok Writing : tzbak Verifying.. ok Done..
Partition : hyp Filename : hyp.mbn StartAddress : 0x8500000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : hyp Size : 56 KB Verifying.. ok Writing : hyp Verifying.. ok Done..
Partition : hypbak Filename : hyp.mbn StartAddress : 0x8580000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : hypbak Size : 56 KB Verifying.. ok Writing : hypbak Verifying.. ok Done.. File Skipped [Not Exists] : /A File Skipped [Not Exists] : /A File Skipped [Not Exists] : /A File Skipped [Not Exists] : /A File Skipped [Not Exists] : /A File Skipped [Not Exists] : /A
Partition : splash Filename : splash.img StartAddress : 0x8b02400 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : splash Size : 5401 KB Verifying.. ok Writing : splash Verifying.. ok Done.. File Skipped [Not Exists] : /A
Partition : fsg Filename : S86518C1_Online_V011.img StartAddress : 0xc008000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : fsg Size : 66 KB Verifying.. ok Writing : fsg Verifying.. ok Done..
Partition : sec Filename : sec.dat StartAddress : 0xc188000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : sec Size : 0 KB Verifying.. ok Writing : sec Verifying.. ok Done..
Partition : boot Filename : boot.img StartAddress : 0xc18c000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : boot Size : 7492 KB Verifying.. ok Writing : boot Verifying.. ok Done..
Partition : system Filename : system_1.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 131080 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_2.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_3.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 128668 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_4.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 129140 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_5.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_6.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_7.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 128656 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_8.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_9.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 129140 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_10.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_11.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_12.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 128656 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_13.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_14.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 129068 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_15.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_16.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_17.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 128656 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_18.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_19.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 129136 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_20.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_21.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_22.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 128656 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_23.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_24.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 125712 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_25.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_26.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 27672 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_27.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_28.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_29.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 8 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : system Filename : system_30.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : system Verifying.. ok Uploading : system Size : 6260 KB Verifying.. ok Writing : system Verifying.. ok Done..
Partition : persist Filename : persist_1.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : persist Size : 4720 KB Verifying.. ok Writing : persist Verifying.. ok Done..
Partition : cache Filename : cache_1.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : cache Verifying.. ok Uploading : cache Size : 1508 KB Verifying.. ok Writing : cache Verifying.. ok Done..
Partition : cache Filename : cache_2.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : cache Verifying.. ok Uploading : cache Size : 8 KB Verifying.. ok Writing : cache Verifying.. ok Done..
Partition : cache Filename : cache_3.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : cache Verifying.. ok Uploading : cache Size : 8 KB Verifying.. ok Writing : cache Verifying.. ok Done..
Partition : cache Filename : cache_4.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : cache Verifying.. ok Uploading : cache Size : 8 KB Verifying.. ok Writing : cache Verifying.. ok Done..
Partition : cache Filename : cache_5.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : cache Verifying.. ok Uploading : cache Size : 4204 KB Verifying.. ok Writing : cache Verifying.. ok Done..
Partition : recovery Filename : recovery.img StartAddress : 0x90f8c000 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : recovery Size : 8128 KB Verifying.. ok Writing : recovery Verifying.. ok Done.. File Skipped [Not Exists] : /A File Skipped [Not Exists] : /A File Skipped [Not Exists] : /A
Partition : userdata Filename : userdata_1.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 46936 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_2.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_3.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_4.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_5.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_6.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_7.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_8.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_9.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_10.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_11.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_12.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_13.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_14.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_15.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_16.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_17.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_18.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_19.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_20.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_21.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_22.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_23.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_24.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_25.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_26.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_27.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_28.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_29.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_30.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_31.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_32.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_33.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_34.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_35.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_36.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_37.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_38.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_39.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_40.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_41.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_42.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_43.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_44.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_45.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_46.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 8 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : userdata Filename : userdata_47.img StartAddress : Reading Data : Please Wait Max Write Size : 268435456 bytes Erasing : userdata Verifying.. ok Uploading : userdata Size : 95672 KB Verifying.. ok Writing : userdata Verifying.. ok Done..
Partition : PrimaryGPT Filename : gpt_main0.bin StartAddress : 0x0 Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : PrimaryGPT Size : 17 KB Verifying.. ok Writing : PrimaryGPT FAILED (remote: partition table doesn't exist) Done..
Partition : BackupGPT Filename : gpt_backup0.bin StartAddress : (512*NUM_DISK_SECTORS)-16896. Reading Data : Please Wait Max Write Size : 268435456 bytes Uploading : BackupGPT Size : 16 KB Verifying.. ok Writing : BackupGPT FAILED (remote: partition table doesn't exist) Done..
Running Post Flash Tasks.. Making Factory Reset.. Rebooting.. All Done...
Read The Rules Carefully !!!
+919655528882
POWERED BY
GSM KING MAKER
Page generated in 0.34139 seconds with 9 queries
