12-15-2018, 11:04 | #3617 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Ukraine
Member: 2750401 Status: Offline Thanks Meter: 134 | SM-J105H frp done Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Login.. ok Starting Device Detection.. Phone Found.. COM43 Switching Mode... Okay Reading Pit From Phone... Pit File Saved to Backup Folder.. Starting Frp Remove New Method.. Writing Patch Data.. Applying Patch Data... Frp Removed ok.. Frp Remove Process Done... Rebooting Phone... All Done. |
12-22-2018, 07:08 | #3623 (permalink) |
Junior Member Join Date: Feb 2010 Location: Entre Rios Argentina
Member: 1239883 Status: Offline Thanks Meter: 2 | It does not repair imei sm j710mn, it does not patch sert, it does not do anythin |
The Following User Says Thank You to vituko For This Useful Post: |
12-22-2018, 08:47 | #3624 (permalink) |
Major Poster Join Date: Jan 2017 Location: Uzbekistan
Member: 2678617 Status: Offline Thanks Meter: 5 | Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Login.. ok Checking Phone on Selected Port.. Phone Found.. Hw Id : 000000001E0A9000 MsmId : MSM8953 Snapdragon 625 Loader : Qd4SXgdpqJZNsWvafFq4zKK7Mpyoq5t/L2IUK4pIB10= Some Files are Missing [Ldr] Please Reinstall Setup... Process Failed... Falcon Qualcomm Module 3.7a |
12-22-2018, 08:47 | #3625 (permalink) |
12-23-2018, 21:51 | #3626 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2777046 Status: Offline Thanks Meter: 0 | FRP ZTE V9 Vita: First put in FTM, the use rebooter to reboot in EDL and select universal qualcomm. Starting.. Asking Server for Access.. Checking User Details.. ok Checking User Login.. ok Checking Phone on Selected Port.. Phone Found.. Hw Id : 000040001E0B6000 MsmId : MSM8937 Snapdragon 430 Loader : 88zR9sgdavD4oKVjwCEHyRDBdahAqK5BlOM+rPx+1rA= Memory type : Emmc Sending Loader.. Reading Partition Table.. Partition Count : 52 ================================================== =================== Brand : ZTE Model : BLADE V9 VITA Android Version : 8.0.0 Id : TEL_MX_BLADE_V9_VITAV1.0.1 Cpu : arm64-v8a Security Patch Level : 2018-09-01 ================================================== =================== Removing Frp.. Writing Block : 23A87400 - 80000 Rebooting Phone.. Process Done... |
