Falcon Box v4.2 Released - Massive Xiaomi Update, Huawei offline Frp (World's First) Miracle Falcon Box Main Module v4.2 Released on 15TH JULY 2018 Powered by Miracle Team Supports Also Miracle Key & THUNDER Activated Users [+] Xiaomi Read Info (Adb-Fastboot-Diag-Edl) [+] Xiaomi Account/Frp Reset in (Edl-Fastboot-Adb) [+] Xiaomi Anti Lock Relock Option While Reset [+] Xiaomi One Click Safe Factory Reset in (Edl-Fastboot-Adb) [+] Xiaomi One Click Factory Reset in Sideload Mode [+] Xiaomi One Click Bypass Account Lock Relock in Adb Mode [+] Xiaomi One Click Cloud/Account Apk Remove [+] Xiaomi One Click Rebooter [+] Adb to Edl, Adb to Fastboot, Fastboot to Edl [+] Force Fastboot to Edl [+] Read/Write/Reset Security in (Edl-Fastboot-Adb) [+] Read/Write Qcn in Diag Mode [+] Erase Imei in Edl/Fastboot Mode Database [+] Imei Repair 4 Different Methods [+] Enable Diag 2 Different Methods [+] Xiaomi Show Sec Patch Level [+] Xiaomi Model/Fw Code Identifier in Fastboot [+] Xiaomi Flashing [+] One Click Zip Flasher in Fastboot or Edl Mode [+] One Click bat Flasher in Fastboot or Edl Mode [+] Option to Remove FRP/Account Lock While Flashing [+] Option to Factory Reset While Flashing [+] **Option to Patch Firmware (Anti Lock Relock) while Flashing** Following Models Supported : Code: [+] [2012051] MI 1S (3G) Some of The Features are in Beta Stage, Do Test and Report! [+] Huawei Offline FRP Reset in MTP Mode [+] No Need Credits or Packs [+] Enable Adb Code: [+] Huawei P20 [+] Improved Asus Raw Firmware Extraction [+] Improved Zte Internel Loaders Database [+] Fixed Serial Mismatch Error [+] Improved Server Connection Still Not Have Falcon? Soon Big Surprise ;) Make Sure You Check our Free Packs https://s20.postimg.org/on3keu1pp/im...t_22_43_10.jpg http://miracleboxserver.com/images/h...tion_small.png http://skstroi.ru/wp-content/uploads.../foot-line.png http://miracleboxserver.com/images/h...-Tool-Logo.png http://skstroi.ru/wp-content/uploads.../foot-line.png http://miracleboxserver.com/images/h...test_setup.png http://miracleboxserver.com/images/h...test_setup.pnghttp://miracleboxserver.com/images/h...test_setup.png http://miracleboxserver.com/images/h...test_setup.png BR [SV]'S MIRACLE TEAM |
MIRACLE FALCON NOW AVAILABLE ON MIRACLE KEY & MIRACLE THUNDER USERS http://miracleboxserver.com/images/h...offer35usd.png Miracle Falcon Activation Available for Miracle Key # No Need Login Auto Login # All Free Packs Available # No Need buy Other Dongle or Card This is Summer Offer any time will Stop. |
Reserved for Team News.. |
Good, the new mode Huawei Offline Frp Reset in MTp Mode, with which mobile is compatible with all or only with the aforementioned Huawei P20, Huawei P20 Pro, Huawei Mate RS, Huawei Honor 10, Huawei Honor Play, thanks. |
Huawei is good update please add more,,, |
Account remove in fastboot mode failed Quote:
Can i remove xiaomi redmi Y2 mi account remove????? |
@kinio_64 this device edl operations will be added in next update you can in this version do all fastboot operations such as patch anti relock etc might need bl unlock in some cases edl operations for this along with network repair and raw flasher will be added in next release br |
Also can you point me to where I can get firmware for mi5 (gemini) in zip format? I have zip archive for recovery mode flash from xiaomi website but Falcon 4.2 can't use that file for some reason, after file is extracted there is nothing to chose in drop down list. All mi5 firmwares in with *. Bat files fails to flash in Falcon but at the same time work fine in official miflasher. Best regards |
i can see your firmware was patched by falcon before giving error in edl you can flash the patched firmware using miflashtool br |
BR |
I can confirm now that i cant use Falcon 4.1 to bypass Mi account any more, process hangs at "Starting Data Download..." stage and its not going any farther, in task manager i can see good 30~45% cpu load on falcon box exe but it seems to be stuck. i have waited for over 30min now without success. Falcon 3.8 was bypassing Mi account in few seconds flat... Sorry for bothering you so much but is there any other way about it? |
Any idea of unlock mi account of Mi6 with this box...all other box (UMT, Inferno, Miracle, Inifinity, etc) not works on unlock or bypass process. Best Regards... Fabiano |
really falcon key rock the world.....only MTK not work |
