07-11-2018, 17:17 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Emmc & Ufs Chips Age: 42
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | Miracle Falcon Samsung v2.0 (Thunder Edition) Released [11th July 2018] Next Generation Multi Brand Tool iNNOVATED BY MIRACLE TEAM Miracle Falcon Samsung v2.0 (Thunder Edition)[11th July 2018] [+] Miracle Thunder & Miracle Key Support For All Modules (Activation Required) Release Notes Added [+] New Method for Samsung Frp, Reactivation, EE Removal in Download Mode [+] Fixed Manual Flashing for Single Partition Flashing [+] Knox Disable (Root Required) [+] Improved Boot Maker (Fixed Missing Patch Folder) [+] Auto Autorization when you open Module [+] Unievrsal Write Cert uart method Samsung Tool Main Supported Features Read Info (Full Device Info) -Normal Mode -Diag Mode -At Mode -Uart Mode Network Unlock -Read Codes -Direct Unlock -Relock to Any Network (Mcc/Mnc) Region Unlock -Region Unlock New and Old Devices one Click Repair Tool -Repair Imei 1, Imei2, Serial, Wifi, BT, Prod Code, Hw_Ver -Read and Write (Check Supported Device List) Cert Tool -Read Cert (Check Supported Model List) -Write Cert (Check Supported Model List) -Full Verify/Check Cert File Compare with keyid -Read Skey id from Phone -Find Key id by Model -Repair Network / Patch Cert (Check Supported Model List) Misc -Enable all Languages -Repair Drk -Repair Drk adb -Exit Factory Mode -Remove Callme Lock Beta -Enable diag (2 methods) -Enable Uart Mode -Reset Msl Backup -Read/write Nvdata -Read/write Qcn Samsung Flasher -Factory Samsung Flasher -Custom File Flasher -Flash any Single File -Flash Single Partition without full Flash -Wipe any Partition -Read Pit -Analyse Put -Fix Download Mode loop Frp Tool (5 Different Methods) -Old Security -New Security -Uart Method -Adb Model -Reactivation/EE Lock Removal Screenlocks -Reset Screenlocks Samsung 4.x/2.x without Root -Reset Locks for adb Enable Devices -Factory Reset [+] New Method for Samsung Frp, Reactivation, EE Removal in Download Mode SM-A310M SM-A310Y SM-A310F SM-A310N0 SM-A310X SM-A320F SM-A320FL SM-A320Y SM-A510K SM-A510L SM-A510S SM-A510F SM-A510FD SM-A510M SM-A510Y SM-A5100 SM-A520F SM-A520K SM-A520L SM-A520S SM-A7108 SM-A710F SM-A710FD SM-A710L SM-A710K SM-A710M SM-A710S SM-A710X SM-A710Y SM-A7100 SM-A720F SM-A810F SM-A810YZ SM-A9000 SM-A910F SM-J727V SM-J727P SM-J510F SM-J510FN SM-J510G SM-J510Y SM-J510M SM-J330F SM-J330G SM-J701F SM-J701M SM-J710F SM-J710FN SM-J710M SM-J710MN SM-J7108 SM-G390F SM-G550FY SM-G570 SM-G570F SM-G570Y SM-G600FY SM-G610F SM-G610M SM-G610Y SM-G9200 SM-G9208 SM-G9209 SM-G920A SM-G920AZ SM-G920F SM-G920FQ SM-G920I SM-G920K SM-G920L SM-G920P SM-G920R4 SM-G920R6 SM-G920R7 SM-G920S SM-G920T SM-G920T1 SM-G920V SM-G920W8 SM-G920X SM-G9250 SM-G925A SM-G925F SM-G925FQ SM-G925I SM-G925K SM-G925L SM-G925P SM-G925R4 SM-G925R6 SM-G925R7 SM-G925S SM-G925T SM-G925V SM-G925W8 SM-G925X SM-G925Z SM-G9280 SM-G9287 SM-G928A SM-G928C SM-G928F SM-G928G SM-G928I SM-G928K SM-G928L SM-G928N0 SM-G928P SM-G928R4 SM-G928S SM-G928T SM-G928V SM-G928W8 SM-G928X SM-G9300 SM-G9308 SM-G930A SM-G930AZ SM-G930F SM-G930FD SM-G930K SM-G930L SM-G930P SM-G930R4 SM-G930R7 SM-G930S SM-G930T SM-G930T1 SM-G930V SM-G930W8 SM-G930X SM-G9350 SM-G935A SM-G935F SM-G935FD SM-G935K SM-G935L SM-G935P SM-G935R4 SM-G935S SM-G935T SM-G935V SM-G935W8 SM-G935X SM-T820 SM-T825 SM-N9200 SM-N9208 SM-N9209 SM-N920A SM-N920C SM-N920CD SM-N920F SM-N920G SM-N920I SM-N920K SM-N920L SM-N920P SM-N920R4 SM-N920R6 SM-N920R7 SM-N920S SM-N920T SM-N920V SM-N920W8 SM-N920X Br [SV] Miracle Team Last edited by Winter Soldier; 07-27-2018 at 02:01. |
The Following 12 Users Say Thank You to chinchik For This Useful Post: |
07-11-2018, 17:17 | #2 (permalink) |
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | Miracle Falcon Box Shell [ Thunder Edition ] NEWS[+] Miracle Thunder Support For All Modules (Activation Required) Last edited by [SV]; 10-21-2018 at 10:52. |
The Following User Says Thank You to chinchik For This Useful Post: |
07-11-2018, 17:17 | #3 (permalink) |
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | MIRACLE FALCON NOW AVAILABLE ON MIRACLE KEY & MIRACLE THUNDER USERS Miracle Falcon Activation Available for Miracle Key # No Need Login Auto Login # All Free Packs Available # No Need buy Other Dongle or Card This is Summer Offer any time will Stop. |
The Following 2 Users Say Thank You to chinchik For This Useful Post: |
07-22-2018, 04:51 | #7 (permalink) |
Crazy Poster Join Date: Jan 2007 Location: dominican republic
Member: 423898 Status: Offline Thanks Meter: 5 | good night greeting I'm having some problems with this module I have miracle box + key and just activate my key for falcon but the samsung module gives me an error that when I try to read a samsung device the module closes only automatically and try to reinstall it and I continue with the same problem |
07-26-2018, 15:53 | #12 (permalink) |
Freak Poster Join Date: Apr 2017
Member: 2711418 Status: Offline Thanks Meter: 28 | Download 2.0 Samsung Here https://url.gem-flash.com/g1XZ |
The Following 5 Users Say Thank You to repairs4you2 For This Useful Post: |
07-27-2018, 10:16 | #13 (permalink) |
Junior Member Join Date: Mar 2018
Member: 2822039 Status: Offline Thanks Meter: 4 | Samsung Module closes after i press "Read Info" button..Right after it try's to "Asking server for Access" ..Common...If there is a known problem write about is, say that it will be fixed or something. And i can NOT use old version that was working....Very unprofessional on teams part. |
07-30-2018, 23:43 | #14 (permalink) |
Freak Poster Join Date: Jun 2008 Location: GSMFILE.CO
Member: 790437 Status: Offline Thanks Meter: 38 | link to download URL="http://www.mediafire.com/file/b37y0q9vj1n8ds8/Falcon+Samsung+Pack+2.0.exe"]http://www.mediafire.com/file/b37y0q9vj1n8ds8/Falcon+Samsung+Pack+2.0.exe[/URL] |
The Following User Says Thank You to caldasunlockgsm For This Useful Post: |
