04-03-2017, 12:12 | #16 (permalink) |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | Sent from my XT1030 using Tapatalk |
The Following User Says Thank You to appsworlmardan For This Useful Post: |
04-03-2017, 15:06 | #18 (permalink) | ||||
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | Quote:
Coolpad dazen is good dump ! Please send me your log Quote:
Thanks | ||||
The Following User Says Thank You to FAT-ON For This Useful Post: |
04-06-2017, 12:04 | #20 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Andhra Pradesh Age: 38
Member: 1612111 Status: Offline Sonork: 100.1586314 Thanks Meter: 52 | where as in coolpad dazen 1 in 8297L-W01_0x0000 u provided csd file and in 8297L-100_0x0000 there was no csd file..check once |
04-06-2017, 12:34 | #21 (permalink) |
Member: 1612111 Status: Offline Sonork: 100.1586314 Thanks Meter: 52 | coolpad dazen 1 CID:0xB8E3524A 0x05076CB7 0x38473165 0x90014A48 Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847316505 (H8G1e) Product revision:0x07 Product serial number:0x6CB7B8E3 Manufacturing date:0x52 CRC7 checksum:0x4A CSD:0x8A4040D2 0xFFFFFFEF 0x0F5903FF 0xD0270132 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x69 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0001D2 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Writing Started... Writing Done !! CID:0xB8E3524A 0x05076CB7 0x38473165 0x90014A48 Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847316505 (H8G1e) Product revision:0x07 Product serial number:0x6CB7B8E3 Manufacturing date:0x52 CRC7 checksum:0x4A CSD:0x8A4040D2 0xFFFFFFEF 0x0F5903FF 0xD0270132 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x69 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0001D2 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB CID:0xB8E3524A 0x05076CB7 0x38473165 0x90014A48 Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847316505 (H8G1e) Product revision:0x07 Product serial number:0x6CB7B8E3 Manufacturing date:0x52 CRC7 checksum:0x4A CSD:0x8A4040D2 0xFFFFFFEF 0x0F5903FF 0xD0270132 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x69 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x05 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0001D2 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB |
04-06-2017, 12:51 | #22 (permalink) | |||
The Problem is that we have 2 different eMMCs in different boards You have hynix and i have Samsung . We will check Dazen 1 Firmware for more information . Quote:
04-06-2017, 14:27 | #23 (permalink) | |
Insane Poster Join Date: Nov 2009 Location: near train station
Member: 1160717 Status: Offline Thanks Meter: 32 | Quote:
when emmc pro can do it? when????? | |
04-06-2017, 18:18 | #24 (permalink) | |
We will release it when it is ready ! We got it here with 1.08 Release and we will go further with more features . Features those we mentioned all the way demanded by our Customers included Vendor commands , patch CID etc and some UI Functions parsing flash files ( MTK , Samsung ) Developing period usually takes time and it is even harder when you have more products in your hand . I can say ; ORT , eMMC Pro and some of our " New Product " will start getting updates . We ask some little patience from our customers and meantime we will keep releasing new models . Best Regards F4T0N | |
04-09-2017, 10:55 | #25 (permalink) |
Member: 1612111 Status: Offline Sonork: 100.1586314 Thanks Meter: 52 | i am having another coolpad dazen 1 working phone in my hands.. can u explain me how to read full flash file i tried reading boot 1,user area and boot 2 and ext_cds as u showin in youtube videos..ut no use.. can u help me |
04-09-2017, 12:12 | #26 (permalink) | |
Junior Member Join Date: Mar 2016
Member: 2552995 Status: Offline Thanks Meter: 0 | Quote:
If you want to backup Dump from good device
ADB Backup can be readed from rooted phone and for the Dazen 1 Case you can only read USER Area Dump and write to dead one with eMMC Pro and this will work fine . For eMMC Pro Backup ( Dazen 1 ) 1 - Detect 2 - Select Size ( at the end of size list ) for full backup 3 - Click Read and locate the file you want to save into Make sure you have enough space in your disk 4 - Click Ok and wait for process to finish . Best Regards | |
