Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 08-16-2017, 10:02   #1 (permalink)
matchbox18's Avatar
Member: 517757
Thanks Meter: 55
help for g532gdeadboot
full flash but stiil dead
what procedure to do
logs
eMMC PRO
eMMC Pro - eMMC Programmer Version V1.10
FIRMWARE(0x4D41494E) version:2017052915210004
SN:0F6820D991B5B16B
eMMC Pro is Ready ..
Connect a Device and Click "Detect"
CID:0x90014A48 0x38473475 0x92011894 0xCCC6341E
Manufacturer ID:0x90
Device/BGA:1 (removable:1 BGA:2 POP:3)
OEM/Application ID:0x4A
Product name:0x483847347592 (H8G4u’)
Product revision:0x01
Product serial number:0x1894CCC6
Manufacturing date:0x34
CRC7 checksum:0x1E
CSD:0xD0270132 0x0F5903FF 0xFFFFFFE7 0x8A40002A
CSD structure:0x3
System specification version:0x4
Data read access-time 1:0x27
Data read access-time 2:0x1
Max. bus clock frequency:0x32
Card command classes:0x0F5
Max. read data block length:0x9 (512)
Partial blocks for read allowed:0
Write block misalignment:0
Read block misalignment:0
DSR implemented:0
Device size:0xFFF
Min. read current @ VDD min:0x7
Max. read current @ VDD min:0x7
Min. write current @ VDD min:0x7
Max. write current @ VDD min:0x7
Device size multiplier:0x7
Erase group size:0x1F
Erase group size multiplier:0x1F
Write protect group size:0x7
Write protect group enable:1
Manufacturer default ECC:0
Write speed factor:2
Max. write data block length:0x9
Partial blocks for write allowed:0
Content protection application:0
File format group(R/W):0
Copy flag (OTP)(R/W):0
Permanent write protection(R/W):0
Temporary write protection(R/W):0
File format(R/W):0
ECC code(R/W):0
CRC(R/W):0x15
Not used, always ’1’:0
RCA:0x00000000
EXT_CSD information parsing:
FFU features:0x00
BOOT_SIZE_MULTI[226]:0x20
HC_ERASE_GRP_SIZE[224]:0x01
ERASE_TIMEOUT_MULT[223]:0x02
HC_WP_GRP_SIZE[221]:0x08
SEC_COUNT(EXT_CSD[215:212]:0x00E90000)
CARD_TYPE(EXT_CSD[196]):0x57
CSD_STRUCTURE(EXT_CSD[194]):0x02
EXT_CSD_REV(EXT_CSD[192]):0x07
PARTITION_CONFIG[179]:0x48
Boot partition 1 enabled for boot
BOOT_CONFIG_PROT[178]:0x00
BOOT_BUS_CONDITIONS[177]:0x00
ERASE_GROUP_DEF[175]:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
RPMB_SIZE_MULT[168]:0x20
WR_REL_SET[167]:0x1F
WR_REL_PARAM[166]:0x15
SANITIZE_START[165]:0x00
BKOPS_START[164]:0x00
BKOPS_EN[163]:0x00
RST_n_FUNCTION[162]:0x01
HPI_MGMT[161]:0x00
PARTITIONING_SUPPORT[160]:0x07
MAX_ENH_SIZE_MULT[159:157]:0x0003A4
PARTITIONS_ATTRIBUTE[156]:0x00
PARTITION_SETTING_COMPLETED[155]:0x00
GP_SIZE_MULT[154:143]:0x000000000000000000000000
ENH_SIZE_MULT[142:140]:0x000000
ENH_START_ADDR[139:136]:0x00000000
SEC_BAD_BLK_MGMNT[134]:0x00
PRODUCTION_STATE_AWARENESS[133]:0x00
TCASE_SUPPORT[132]:0x00
PERIODIC_WAKEUP[131]:0x00
PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00
NATIVE_SECTOR_SIZE[63]:0x01
USE_NATIVE_SECTOR[62]:0x00
DATA_SECTOR_SIZE[61]:0x00
INI_TIMEOUT_EMU[60]:0x0A
Class6_CTRL[59]:0x00
DYNCAP_NEEDED[58]:0x00
EXCEPTION_EVENTS_CTRL[57:56]:0x00
EXCEPTION_EVENTS_STATUS[55:54]:0x00
EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00
CONTEXT_CONF[51:37]:0x000000000000000000000000000000
PACKED_COMMAND_STATUS[36]:0x00
PACKED_FAILURE_INDEX[35]:0x00
POWER_OFF_NOTIFICATION[34]:0x00
CACHE_CTRL[33]:0x00
FLUSH_CACHE[32]:0x00
MODE_CONFIG[30]:0x00
MODE_OPERATION_CODES[29]:0x00
FFU_STATUS[26]:0x00
PRE_LOADING_DATA_SIZE[25:22]:0x00000000
MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00
PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01
SECURE_REMOVAL_TYPE[16]:0x3B
Basic Information:
Extended CSD revision:
User Data Area Size: 7456MB(0x1D2000000)
Boot Partition Size: 4096KB
RPMB Size: 4096KB
General Purpose Partition 1 Size: 0KB
General Purpose Partition 2 Size: 0KB
General Purpose Partition 3 Size: 0KB
General Purpose Partition 4 Size: 0KB
Erase group size: 512KB
Writing Started...
Writing preloader1.bin ...
Writing pgpt.bin ...
Writing lk.bin ...
Writing secro.bin ...
Writing efuse.bin ...
Writing tee1.bin ...
Writing param.bin ...
Writing recovery.bin ...
Writing boot.bin ...
Writing md1img.bin ...
Writing md1dsp.bin ...
Writing Done !
The Following 2 Users Say Thank You to matchbox18 For This Useful Post:
Old 08-16-2017, 11:11   #2 (permalink)
matchbox18's Avatar
Member: 517757
Thanks Meter: 55
can you give the step by step procedure
Old 08-18-2017, 11:08   #3 (permalink)
matchbox18's Avatar
Member: 517757
Thanks Meter: 55
huhuhuhu no 1 answer
Old 08-22-2017, 05:15   #4 (permalink)
Member: 2091560
Sonork: 000000
Thanks Meter: 44
G532g after repair boot done not open not work help.
The Following User Says Thank You to KIKO_PH For This Useful Post:
Old 08-22-2017, 06:57   #5 (permalink)
Member: 2091560
Sonork: 000000
Thanks Meter: 44
After repair boot not work
eMMC PRO
SN:6A460B0024049B80
CID:0x90014A48 0x38473475 0x92011818 0x39363444
Product serial number:0x18183936
CRC7 checksum:0x44
CSD structure:0x3
DSR implemented:0
Device size:0xFFF
File format(R/W):0
ECC code(R/W):0
CRC(R/W):0x15
RCA:0x00000000
FFU features:0x00
PARTITION_CONFIG[179]:0x00
Device not boot enabled (default)
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
WR_REL_SET[167]:0x00
BKOPS_EN[163]:0x00
HPI_MGMT[161]:0x00
PARTITION_SETTING_COMPLETED[155]:0x01
PERIODIC_WAKEUP[131]:0x0A
CACHE_CTRL[33]:0x00
FFU_STATUS[26]:0x00
Basic Information:
RPMB Size: 4096KB
Writing Started...
Writing lk.bin ...
Writing Done !
CRC7 checksum:0x44
CSD structure:0x3
DSR implemented:0
Device size:0xFFF
File format(R/W):0
ECC code(R/W):0
CRC(R/W):0x15
RCA:0x00000000
FFU features:0x00
BOOT_WP[173]:0x00
USER_WP[171]:0x00
FW_CONFIG[169]:0x00
BKOPS_EN[163]:0x00
HPI_MGMT[161]:0x00
CACHE_CTRL[33]:0x00
FFU_STATUS[26]:0x00
Basic Information:
RPMB Size: 4096KB
Writing Started...
Writing preloader.img ...
Writing gpt.bin ...
Writing pit.bin ...
Writing lk.bin ...
Writing efuse.img ...
Writing trustzone.bin ...
Writing Done !
Writing Started...
Writing gpt.bin ...
Writing pit.bin ...
Writing lk.bin ...
Writing Done !
Old 08-22-2017, 11:56   #6 (permalink)
Member: 2547620
Thanks Meter: 3,431
This file is tested and work for deadboot internally .
Please contact our facebook support to check remotely .
The Following User Says Thank You to FAT-ON For This Useful Post:
Old 05-27-2018, 10:30   #7 (permalink)
-=jeovel=-'s Avatar
Member: 1604158
Sonork: 100.1614304
Thanks Meter: 122
This file is not Tested very insane Product Support
if the file is working why after writing still not power on..
Old 05-28-2018, 09:34   #8 (permalink)
Member: 2547620
Thanks Meter: 3,431
check your eMMC config BOOT config .
G532G lose the config since it is a hynix bug in the firmware .
should be booting from BOOT1 with ACK
Old 05-31-2018, 12:49   #9 (permalink)
Member: 513210
Thanks Meter: 110
i do this procedure you told but why my g532g still not power on
what excactly right procedure i do to get back my phone alive
plz give time to how make it.....
Old 06-15-2018, 11:44   #10 (permalink)
Member: 2547620
Thanks Meter: 3,431
This is wrong configuration for this phone ,
Set this in Config menu
PS : after set this setting , detect the chip few times .. and check if it is losing the configuration
in some cases bad firmware and eMMC should be replaced !
Best Regards
Old 06-16-2018, 06:47   #11 (permalink)
Member: 1711141
Thanks Meter: 45
Best Regards
this is why we need corect guide how we revive those phone....
The Following User Says Thank You to lhongzkie For This Useful Post:
Old 06-21-2018, 11:40   #12 (permalink)
Member: 2547620
Thanks Meter: 3,431
updating current manual with more informations .
Best Regards
F4T0N
Old 06-25-2018, 02:59   #13 (permalink)
-=jeovel=-'s Avatar
Member: 1604158
Sonork: 100.1614304
Thanks Meter: 122
Best Regards
Yes i set with this way, but as you said upon set this config and detect the chips again it wil be back in default...
the reason why this phone is dead condition is because they flash with the wrong firmware.. so im sure the EMMC is not damaged..
Old 09-28-2018, 10:17   #14 (permalink)
Member: 463114
Thanks Meter: 3
same problem here. pls fix this.
Old 10-09-2018, 05:49   #15 (permalink)
Member: 2547620
Thanks Meter: 3,431
if chip is back to default over and over again - replace the eMMC .
Best Regards
F4T0N
Page generated in 0.30489 seconds with 9 queries
