help for g532gdeadboot full flash but stiil dead what procedure to do logs eMMC PRO eMMC Pro - eMMC Programmer Version V1.10 FIRMWARE(0x4D41494E) version:2017052915210004 SN:0F6820D991B5B16B eMMC Pro is Ready .. Connect a Device and Click "Detect" CID:0x90014A48 0x38473475 0x92011894 0xCCC6341E Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847347592 (H8G4u) Product revision:0x01 Product serial number:0x1894CCC6 Manufacturing date:0x34 CRC7 checksum:0x1E CSD:0xD0270132 0x0F5903FF 0xFFFFFFE7 0x8A40002A CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0x7 Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):0 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x15 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 HC_WP_GRP_SIZE[221]:0x08 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x48 Boot partition 1 enabled for boot BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x15 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0003A4 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Writing Started... Writing preloader1.bin ... Writing pgpt.bin ... Writing lk.bin ... Writing secro.bin ... Writing efuse.bin ... Writing tee1.bin ... Writing param.bin ... Writing recovery.bin ... Writing boot.bin ... Writing md1img.bin ... Writing md1dsp.bin ... Writing Done ! |
can you give the step by step procedure |
huhuhuhu no 1 answer |
G532g after repair boot done not open not work help. |
After repair boot not work eMMC PRO eMMC Pro - eMMC Programmer Version V1.10 FIRMWARE(0x4D41494E) version:2017052915210004 SN:6A460B0024049B80 eMMC Pro is Ready .. Connect a Device and Click "Detect" CID:0x90014A48 0x38473475 0x92011818 0x39363444 Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847347592 (H8G4u’) Product revision:0x01 Product serial number:0x18183936 Manufacturing date:0x34 CRC7 checksum:0x44 CSD:0xD0270132 0x0F5903FF 0xFFFFFFE7 0x8A40002A CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0x7 Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):0 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x15 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 HC_WP_GRP_SIZE[221]:0x08 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x00 WR_REL_PARAM[166]:0x15 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0003A4 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x0A PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Writing Started... Writing preloader1.bin ... Writing pgpt.bin ... Writing lk.bin ... Writing secro.bin ... Writing efuse.bin ... Writing tee1.bin ... Writing param.bin ... Writing recovery.bin ... Writing boot.bin ... Writing md1img.bin ... Writing md1dsp.bin ... Writing Done ! CID:0x90014A48 0x38473475 0x92011818 0x39363444 Manufacturer ID:0x90 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x4A Product name:0x483847347592 (H8G4u’) Product revision:0x01 Product serial number:0x18183936 Manufacturing date:0x34 CRC7 checksum:0x44 CSD:0xD0270132 0x0F5903FF 0xFFFFFFE7 0x8A40002A CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x7 Max. read current @ VDD min:0x7 Min. write current @ VDD min:0x7 Max. write current @ VDD min:0x7 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0x7 Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:2 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):0 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x15 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x02 HC_WP_GRP_SIZE[221]:0x08 SEC_COUNT(EXT_CSD[215:212]:0x00E90000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x00 WR_REL_PARAM[166]:0x15 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0003A4 PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x0A PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x00 NATIVE_SECTOR_SIZE[63]:0x01 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x0A Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x01 SECURE_REMOVAL_TYPE[16]:0x3B Basic Information: Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Writing Started... Writing preloader.img ... Writing gpt.bin ... Writing pit.bin ... Writing lk.bin ... Writing efuse.img ... Writing trustzone.bin ... Writing param.bin ... Writing Done ! Writing Started... Writing preloader.img ... Writing gpt.bin ... Writing pit.bin ... Writing lk.bin ... Writing efuse.img ... Writing trustzone.bin ... Writing param.bin ... Writing Done ! |
Please contact our facebook support to check remotely . |
https://s22.postimg.cc/6yf88wgv5/Capture.png if the file is working why after writing still not power on..:mad: |
check your eMMC config BOOT config . G532G lose the config since it is a hynix bug in the firmware . should be booting from BOOT1 with ACK |
what excactly right procedure i do to get back my phone alive plz give time to how make it.....:mad: |
Set this in Config menu http://i63.tinypic.com/2jazpe9.png PS : after set this setting , detect the chip few times .. and check if it is losing the configuration in some cases bad firmware and eMMC should be replaced ! Best Regards |
this is why we need corect guide how we revive those phone.... |
updating current manual with more informations . Best Regards F4T0N |
the reason why this phone is dead condition is because they flash with the wrong firmware.. so im sure the EMMC is not damaged.. |
same problem here. pls fix this. |
if chip is back to default over and over again - replace the eMMC . Best Regards F4T0N |
