06-12-2017, 18:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | htc 820u boot repair sucessfully but still dead Code: www.emmc-pro.com eMMC Pro - eMMC Programmer Version V1.09 FIRMWARE(0x4D41494E) version:2017052915210004 SN:C4812FAF8F3C7D8E eMMC Pro is Ready .. Connect a Device and Click "Detect" CID:0x15010041 0x574D4233 0x5201989C 0x45BEB1EC Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x41574D423352 (AWMB3R) Product revision:0x01 Product serial number:0x989C45BE Manufacturing date:0xB1 CRC7 checksum:0xEC CSD:0xD0270132 0x0F5903FF 0xF6DBFFEF 0x92404008 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x6 Max. read current @ VDD min:0x6 Min. write current @ VDD min:0x6 Max. write current @ VDD min:0x6 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:4 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x4 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x01D1F000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x04 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x01 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x00026D PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x00 Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x09 Basic Information: Extended CSD revision: User Data Area Size: 14910MB(0x3A3E00000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Area is changed to BOOT1(size:0x00400000) Area is changed to BOOT1(size:0x00400000) Area is changed to BOOT1(size:0x00400000) Writing Started... Writing Done !! Area is changed to BOOT2(size:0x00400000) Writing Started... Writing Done !! Area is changed to EXT_CSD(size:0x200) Writing Started... Writing Done ! CID:0x15010041 0x574D4233 0x5201989C 0x45BEB1EC Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x41574D423352 (AWMB3R) Product revision:0x01 Product serial number:0x989C45BE Manufacturing date:0xB1 CRC7 checksum:0xEC CSD:0xD0270132 0x0F5903FF 0xF6DBFFEF 0x92404008 CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x6 Max. read current @ VDD min:0x6 Min. write current @ VDD min:0x6 Max. write current @ VDD min:0x6 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:4 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x4 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x01D1F000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x04 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x01 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x00026D PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x00 Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x09 Basic Information: Extended CSD revision: User Data Area Size: 14910MB(0x3A3E00000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB |
07-06-2017, 12:02 | #4 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | Hİ bro fİrst deep erase and soft erase after boot partİtİon boot1-2 rpm 4mb select wrİted after extcsd wrİted after dump wrİted try |
The Following 2 Users Say Thank You to mathew_di For This Useful Post: |
