03-29-2017, 16:44 | #5 (permalink) |
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | We found SCL-AL00 called honor 4 here I can do this model and it has msm 8909 I can't find the same model but connections probably will be same and maybe we can match board firmware for your model. Let's keep working Best regards F4T0N |
The Following User Says Thank You to FAT-ON For This Useful Post: |
03-31-2017, 13:17 | #9 (permalink) |
Member: 2547620 Status: Offline Thanks Meter: 3,431 | We just need to confirm whether phones are identical If they are identical eMMC Should be programmed by removing Waiting for picture . Best Regards F4T0N |
04-01-2017, 08:17 | #11 (permalink) |
Member: 2547620 Status: Offline Thanks Meter: 3,431 | It seem boards are identical so the problem remains that there is no CLK available , so if you guys are willing to repair by removing eMMC IC . I have the dump ( SCL-AL00 ) and i will prepare repair file for ( SCL-U31 ) too Here is the picture . |
