Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 12-06-2016, 10:51   #1 (permalink)
vickyjadhav6161's Avatar
Member: 2386560
Sonork: NOW I DON'T USE IT
Thanks Meter: 561
P 3100 still dead
eMMC PRO
eMMC Pro - eMMC Programmer Version V1.07
FIRMWARE(0x4D41494E) version:2014053015000002
SN:C4812FAF8F3C7D8E
eMMC Pro is Ready ..
Connect a Device and Click "Detect"
CID:0x9C3A5F36 0x4105C804 0x41473247 0x1501004D
CSD:0x8A404006 0xF6DBFFFF 0x0F5903FF 0xD0270132
RCA:0x00000000
BOOT_SIZE_MULTI(EXT_CSD[226]):0x10
SEC_COUNT(EXT_CSD[215:212]:0x01D5A000)
CARD_TYPE(EXT_CSD[196]):0x07
CSD_STRUCTURE(EXT_CSD[194]):0x02
EXT_CSD_REV(EXT_CSD[192]):0x05
RPMB_SIZE_MULT(EXT_CSD[168]):0x01
Basic Information
Extended CSD revision: Revision 1.5 (MMC v4.41)
User Data Area Size: 15028MB(0x3AB400000)
Boot Partition Size: 2048KB
RPMB Size: 128KB
General Purpose Partition 1 Size: 0KB
General Purpose Partition 2 Size: 0KB
General Purpose Partition 3 Size: 0KB
General Purpose Partition 4 Size: 0KB
Writing Started...
Writing Done !!
Area is changed to BOOT1(size:0x00200000)
Writing Started...
Writing Done !
Area is changed to BOOT2(size:0x00200000)
Writing Started...
Writing Done !
Area is changed to EXT_CSD(size:0x200)
Old 12-06-2016, 10:58   #2 (permalink)
Member: 2386560
Thanks Meter: 561
the pic which you see, i have write same way b1 b2 extcsd file...
Old 12-06-2016, 11:04   #3 (permalink)
Member: 2547620
Thanks Meter: 3,431
if you write full flash please do not select partition .
Best Regards
F4T0N
The Following User Says Thank You to FAT-ON For This Useful Post:
Old 12-06-2016, 11:13   #4 (permalink)
Member: 2547620
Thanks Meter: 3,431
And when you selected file , you should see the partitions and i can see there is no partition in your software currently .
Old 12-06-2016, 11:16   #5 (permalink)
Member: 2547620
Thanks Meter: 3,431
Just like this.
Add
Ps : No need to write BP1 , 2 or others only write USER area for this phone will be okay/
Best Regards
F4T0N
Old 12-06-2016, 11:42   #6 (permalink)
Member: 2386560
Thanks Meter: 561
Old 12-06-2016, 11:56   #7 (permalink)
Member: 2386560
Thanks Meter: 561
ok i understand, after repair i will report you..thanku
Old 12-07-2016, 08:02   #8 (permalink)
Member: 2386560
Thanks Meter: 561
still dead..........
Old 12-08-2016, 03:52   #9 (permalink)
Member: 2547620
Thanks Meter: 3,431
There might be somethign wrong with your phone hardware rather than having eMMC Boot Problem ,
I just sent you a PM with Full flash image of this phone , you can test .
I will also add into support area in next update .
Best Regards
F4T0N
The Following 2 Users Say Thank You to FAT-ON For This Useful Post:
Page generated in 0.19013 seconds with 8 queries
